Finally Dropped the Max (6th Gen w/19" Rays)
Old Jan 29, 2007 | 08:00 AM
DRod's Avatar
Long overdue, but I finally had the springs in installed on my Maxima. I actually only used the front springs (Eibachs). I was concerned that I'd get alot of pogo, but it feels pretty good. I'm impressed. The only real "complaint" I have is that when you come to a dead stop regardless of how mild or abrupt, the car rocks back n forth just a bit.
Another thing I did is change tire size. When I bought the wheels, they came with 225/35/19s up front and 245/40/19s in the rear, which is the correct size for the speedometer/odometer/etc. So, I moved those up front, and bought 255/40/19s for the rear, which is 1.3% off of stock setting (245/45/18). That's better than the 5.5% the 225s were off by, so I'm not worried. And I went with a Toyo T1R. My second consideration was the Falken FK-452. When my fronts finally need replacing, I can have matching tires.
BEFORE:
AFTER:
Old Jan 29, 2007 | 09:59 AM
86maxima96's Avatar
I Broke OT
tires definitely look a little meatier and the fender gap up front is filled up nicely. looks great! and are those the G35 19"s?
Old Jan 29, 2007 | 10:14 AM
LakeM's Avatar
Its funny how much of a difference that small angle makes on the way the car looks. Very nice.
Old Jan 29, 2007 | 10:24 AM
DRod's Avatar
Yes they are. And thanks.
Old Jan 29, 2007 | 07:41 PM
02theMax's Avatar
Looks much, much better! Is the ride noticably better with the larger diameter tires?
Old Jan 29, 2007 | 07:52 PM
"BLACK MAXIC"'s Avatar
Much Better Look...
Old Jan 29, 2007 | 08:30 PM
DRod's Avatar
Yes, it is. You don't feel every single bump in the road.
Old Feb 5, 2007 | 06:25 AM
Triple8Sol's Avatar
I miss the .org!
Looks good, but I'd suggest some spacers. Prob like 5-10mm rear and 10-15mm front?
Old Feb 5, 2007 | 03:14 PM
DRod's Avatar
Why would I need spacers? Offset difference isn't THAT bad is it? Oh...and thanks.
Old Feb 5, 2007 | 10:57 PM
Triple8Sol's Avatar
I miss the .org!
You don't like the flush look?
Old Feb 6, 2007 | 07:35 AM
DRod's Avatar
I knew that was coming. It's pretty flush. Only a wheel-phile could tell the difference...and that's a maybe. But I understand what you're saying. To the untrained eye (about 99% of car owners), it's flush and I'm cool with that.
Old Mar 4, 2007 | 05:41 PM
ramberg's Avatar
GrandPa
It looks good but Eibach says for safety issues all 4 springs should be installed. I have them all around.
Old Mar 4, 2007 | 06:03 PM
DRod's Avatar
Indeed it does. This is the 2nd car I've had with only the fronts installed. So far (fingers crossed) I've had no issues. But that's definitely something people considering "fronts only" should be aware of.
Old Mar 5, 2007 | 06:51 AM
UnMaTcHeD's Avatar
Not for rookies!!
Looks good man, the same exact setup that I had. I have since sold my wheels and will be installing the rear springs in the upcoming weeks.
Old Mar 5, 2007 | 10:27 AM
Gian13's Avatar
loooking goooooooooood! Awesome wheels!
Old Mar 5, 2007 | 01:59 PM
SweetJones's Avatar
Looks good
Old Mar 10, 2007 | 06:59 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Me likie...................
Old Mar 26, 2007 | 03:38 PM
koolguy4u's Avatar
whoa i like it. wanna get some wheels like that on my max
Lakersallday24
Nov 7, 2024 07:31 PM
dank4us
34
Jun 10, 2024 03:45 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
2k0to2k3
Aug 18, 2015 09:59 AM
maxinout93
Aug 16, 2015 07:25 PM
