225/45/18: rubbing issues
Old Jan 29, 2007 | 09:57 PM
maxim82's Avatar
heres the deal in the front i got 225/45/18 rear 245/45/18 and my car is dropped 1 1/2" front and 1 1/4" rear, my problem is that all four sides are rubbing against the fenders when ever i hit a bump on the road or if i corner hard, i want to have one tire size all around so what tire size would you recommend that wont be rubbing at all?
Old Jan 29, 2007 | 09:58 PM
gtr_rider's Avatar
192.168.1.1
the tires you should have are 235/40-18
Old Jan 29, 2007 | 10:02 PM
maxim82's Avatar
wont those be bigger than the 225/45/18?
Old Jan 31, 2007 | 12:03 AM
SilverGLE's Avatar
I'm watching you, boy...
That size will be wider than the 225 up front, but narrower than the 245 in the rear. The 235/40 will be shorter than the 225/45 and 245/45. If you follow the Tire Size Calculator in the stickies, 235/40/18 (most likely) is the recommended tire size for your Max, and least likely to rub with a drop.
Old Jan 31, 2007 | 07:34 AM
BLUEMAX01SE's Avatar
I've got 245/40 18's dropped on S.Techs and never had any rubbing issues! 235/40 was the recommended size but I went up one notch on the width! Good luck!
Old Jan 31, 2007 | 07:35 AM
spark plugs.'s Avatar
Hi, I drive a Maxima.
no, the 225/45 actually has 7.25mm of overall sidewall
Old Jan 31, 2007 | 07:37 AM
and the 245/45 is actually 16.25 mm more sidewall and 10mm more tread width than what most members recommend for 18's on a maxima.
Old Jan 31, 2007 | 11:09 AM
AcidJake75's Avatar
Originally Posted by irish44j
g 18's are 30mm offset
g 17x8 are 33mm
g 17x7.5 are 30mm
g 17x7 are 40mm
you should be running 225/40/18, not 45 profile.
He posted this thread twice and still everyone keeps telling him the same..LOL..
or at least almost the same --
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
