Pics of My new wheels
Old Sep 10, 2008 | 06:38 PM
allblackmax96's Avatar
some pics of the 5zigen copse i just picked up, they are 18x7.5 with a 43mm offset (i believe) with falken ZE512 tires size 225/40/R18. i deffinately need to lower it, 2 tires are worn pretty good and the others are questionable, i might go with a 235/45R18 next. i think wheel spacers are needed but im not sure what size to go with, any suggestions?
And yeah i put some air in them after the pics were taken, haha
Old Sep 10, 2008 | 07:16 PM
MaxGordon7's Avatar
You got a lift kit?
Old Sep 10, 2008 | 07:31 PM
haha, i know it looks like it, stock setup, i really like the wheels, but i need to at least lower it to make it look right.
Old Sep 10, 2008 | 07:46 PM
MrDicks95SE's Avatar
Offset Is Everything.
wow your tires are really undersized. go with a larger aspect ratio (sidewall). your'e one size too small. 18x7.5 is weak and so is the +43 offset. slap on some wide rubber to make up for it. btw, your front psi looks low.
7.5" are gonna be weird with a wide stance. but for perfect flushness, you'd want a +25 effective in the front and about a +20 effective in the rears. you do the math.
Old Sep 10, 2008 | 08:12 PM
well im gunna ride these tires out till winter and get some 235/45R18's for next year
so would i get 18mm spacers for the rear and 13mm for the front?? i havent had rims before so im a noob with offsets.
Old Sep 10, 2008 | 08:51 PM
so would i get 18mm spacers for the rear and 13mm for the front?? i havent had rims before so im a noob with offsets.[/QUOTE]
used that crazy search function and figured it out
Old Sep 11, 2008 | 01:21 AM
Originally Posted by allblackmax96
so would i get 18mm spacers for the rear and 13mm for the front?? i havent had rims before so im a noob with offsets. used that crazy search function and figured it out
the closest that would work best for you would be a 10 or 15mm up front and a 20mm in the rear.
Old Sep 11, 2008 | 09:23 PM
IHAVEA2KMAXIMA's Avatar
You need some higher profile tires or lower it asap! Also your front passenger tire looks flat. I donno if you get any snow action there, but either way, riding bald is bad.
Old Sep 12, 2008 | 12:40 PM
yeah i got springs on the way, and if you had read my OP, you would see that i had already put air in the after i took the pics, those tires are junk, i rebalanced them at work yesterday and they still shake, its prob a belt in the tire, but i got the whole setup for 400bucks, so im just gunna get some new tires over the winter for the spring.
Old Sep 15, 2008 | 02:04 AM
Triple8Sol's Avatar
I miss the .org!
good god you need a drop
Old Sep 15, 2008 | 03:22 AM
Nice wheels, but too high. Fix that.
Old Sep 15, 2008 | 09:30 PM
G4nismo's Avatar
omg that 1st pic is just...i'm not even gonna say. you gotta get a drop soooooo bad
Old Sep 16, 2008 | 09:38 PM
gatsugansu's Avatar
looks like a 4x4.
Old Sep 18, 2008 | 01:16 AM
MIK3's Avatar
Only if those were 19's with a 35ET with a mild drop and the car would look very clean. Let's see what they look like with the drop.
londonflu
40
Sep 25, 2015 09:11 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
