long crank no speedo no rpm
2004 Infiniti i35 140k miles
After doing the brakes, spark plugs and valve covers, my speedo/odometer does not work. ABS/TCS lights are on. From time to time especially early AM the speedo works for about 10 minutes with the SLIP and TCS lights on (no ABS) but then reverts back to ABS/TCS when fails.
RPM does not show on dash but registers on scanner. Replaced sensor on transmission and no luck.
Long crank before starting - 5 seconds or so. Replaced crankshaft position sensor per error code P0335 from scanner but still a long crank.
other codes U1001, P1212, P1574, P0725. Not sure where to go from here.
Eg2707
12-05-2010 09:54 PM
xUltra
21
09-23-2005 11:29 AM
