1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Finally 1/4 runs, (pic, vid, and slip inside)
Old Dec 24, 2010 | 01:12 PM
  #41
krazy6's Avatar
Originally Posted by streetzlegend
Was it constant? or at WOT? how did you identify which injector it was?
It would misfire at idle. Car sounded cammed lol.
If would do it under WOT too. Car had no power because of it.
The ecu threw a code which told me what cylinder it was. You can ohm test each injector with a multimeter though. Check the resistance on each one. One should be different than all of the others.
Old Dec 24, 2010 | 01:16 PM
  #42
streetzlegend's Avatar
Ill check them out, although I still dont think thats my case, out of WOT driving is perfectly smooth, and AFR at WOT is a flat line across from the time i go WOT to the time i let off.
Old Dec 24, 2010 | 01:22 PM
  #43
Originally Posted by perkman87
Im ready to run. lol
bring it! lol
Old Dec 24, 2010 | 02:49 PM
  #44
stillpimpin's Avatar
How Bout A guy from work told me he saw a green maxima run down the track...In my mind I was like Yea.. Dats Streetz...lol nice numbers, when I get my tranny i need to see what I run...
Old Dec 24, 2010 | 10:11 PM
  #45
Get that tranny already! If money is good try to get a transgo shiftkit so you can put in with the tranny. HD2 is what i got.
Old Dec 25, 2010 | 02:19 AM
  #46
Legit6MT's Avatar
If your misfire occurs when you go WOT, it could be a ignition spark related issue.
1.Re-gap all your spark plugs.
2.Make sure you have no vacuum leak. *Spray brake cleaner all around the manifold and injectors*
3.I would lower the boost see if that makes any difference, if it does then you have an ignition problem.
4.If you already haven't maybe do a grounding kit, and recheck all the ignition wires from the EU to ECU.
Old Dec 25, 2010 | 06:12 AM
  #47
Yea I got the HD2 kit and puttin it on monday..
Old Dec 25, 2010 | 09:32 AM
  #48
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
You seem to be trying to help, but you may want to read first. Let me answer so streetz doesn't pull any more hair out on your behalf.
1. He's regapped his plugs at least 3-4 times.
2. I wonder how much vacuum it pulls at WOT at 5000+ RPMs when he's getting the misfire... I mean really. Vacuum?
3. He's run it on minimum WG boost, and also makes less boost in lower gears due to the giant turbo and seems to still get the misfire.
4. A few others have mentioned the grounding kit, to which he responded that he has meticulously installed a grounding kit, then checked and rechecked it.
Hope you can get the problem solved, streetz... Usually a stuck or bad injector will make it run like crap 100% of the time.
Old Dec 25, 2010 | 10:34 AM
  #49
t6378tp's Avatar
Turbo 3.5
hey, new idea have you never measured the resistance cross different point on the body and harness to confirm the grounds are really good. You could have a bad or slighty broken wire and it will be a ground but not good enough under a heavy load.
Also do you have anything sharing a ground or grounded close to any audio equipment if so move it
Last have you attempted to disconnect the charge side and drive the car n/a to see if it still happens
Old Dec 25, 2010 | 10:36 AM
  #50
t6378tp's Avatar
Turbo 3.5
Ok this is really the last thing since you never answered when I asked if you measured the voltage at the coils, ecu, jns, eu and injectors while driving the car. Doing this will also help to narrow down the problem since you don't have a super duper scan tool
Old Dec 25, 2010 | 01:00 PM
  #51
Legit6MT's Avatar
This happened several times with my UTEC. +1
Old Dec 26, 2010 | 10:26 AM
  #52
Sparks thanks for replying for me
I havent done that yet, I plan go log with Blatz and EU at same time, blatz shows you voltages and alot more things. I gotta get me a digital voltmeter since mine is one of them crappy analog, then run some wires to the coils and check voltages while at WOT, the same do for the EU and INJ, not js cuz that was disconnected completely and still missed, good tips man.
Also for the sound equipment, actually I recently disconnected my sub's amp because it would have noise even when not on, so as it is right now, there is no audio equipment other than stock.
I havent ran the car NA yet, I dont wanna disconnect the charge pipe and WOT because I fear i'll overspin and hurt the turbo, Instead I might cut an old Tial WG spring I have which is already 7psi, so it can open very very soon and not get any boost.
Old Dec 26, 2010 | 10:35 AM
  #53
321VQ35MAX's Avatar
Congrats... 12.8 @ 117 is a real good run.. What were you hoping for?
Can't wait to see with the nitrous..
Old Dec 26, 2010 | 10:50 AM
  #54
Thanks, my goal was to go low 12's maybe high 11s, I think mid 12's is possible once the misfire is gone, or even low 12s. Without nitrous. But for the first time with this setup and first time in about 2 years to the 1/4, I think I did ok.
Old Dec 26, 2010 | 01:43 PM
  #55
A 117 trap could take you well into the 11s if you can find a way to build boost off the line and in 1st gear (without nitrous). If only you could use a 2-step and transbrake to build boost at the tree...
Old Dec 26, 2010 | 03:51 PM
  #56
accordingtou's Avatar
VQ30 DE T
Thankyou
Old Dec 26, 2010 | 04:13 PM
  #57
krazy6's Avatar
Yeah, 117 trap is moving. You'll get 11s, just gonna need some more seat time to figure out what chages you'll need to make.
Old Dec 26, 2010 | 05:45 PM
  #58
Thanks guys, yeah I def need more seat time. I should go to the 1/8th to get some practice and try different things. Gotta take notes from you guys, spark n krazy6.
Old Dec 26, 2010 | 09:25 PM
  #59
Well I got the 2step, but with a stall of 1500 the backfires are way way too violent (too much fuel being ignited since its at such low rpm), when I stall up the converter even almost at WOT still dosnt spin the turbo to build 1psi. So in my case, nitrous is needed, its already setup for it, just a matter of going to the track with it.
Old Dec 26, 2010 | 09:37 PM
  #60
Yeah the low stall kinda kills being able to 2-step and build boost. What size shot will you be spraying in 1st gear? Guessing you'll need at least a 75 shot to pull <1.8 '60s
Old Dec 26, 2010 | 09:39 PM
  #61
Well I have it jetted at 50 and have it programmed so that it sprays from idle to 10psi.
Old Dec 27, 2010 | 09:07 AM
  #62
NiZMo1o1's Avatar
fuuu Andres said it was a A33 Body...
Nice times bro , you didnt call us up ? I would have gone with ya up there...
Old Dec 27, 2010 | 11:18 AM
  #63
My bad, I actually wasnt going to tell anyone at all, well I didnt just a couple of my mustang buddies. Didnt know what times to expect and didnt want to hype it up to run crappy times you get me? lol. Now that I know what the car can do, ill hit you up next time. Cuz next time I am going all out, im calling out Corry! jk jk! lol
btw I saw a very nice looking 5.5gen but was parked, didnt run. Black with what looked to be g37 rims.
Old Dec 27, 2010 | 01:23 PM
  #64
NiZMo1o1's Avatar
I would have gone to watch and support... but yeah hit us up and let us know ahead of time..
Old Dec 27, 2010 | 03:03 PM
  #65
1swtmax's Avatar
Congrats Streetz, I know its not the best the car can do but its a start. I want to go back to the track in the spring to see what the new set up bring. Probably just more wheel spin. lol And the misfire, man that sucks. Good luck.
Old Dec 27, 2010 | 03:24 PM
  #66
Thanks man, yeah hopefully I figure out the missing one day
Old Dec 30, 2010 | 05:59 PM
  #67
VQrebuild96's Avatar
Stuck open EGR maybe? Try blocking off the hoses that go into the IM for the EGR vaccum.
Old Dec 30, 2010 | 09:24 PM
  #68
I dont have an egr,
Old Jan 4, 2011 | 01:25 PM
  #69
Question for everyone, I have learned that with grounds you cant always share many devices with a single ground, does the same apply with positive? 12v that feeds the ECU I have it T'ed and also feeding the J&S, Suprastick, and EU. Should I find another source and get load off the ecu's power?
Old Jan 4, 2011 | 01:41 PM
  #70
Definitely! When I had both my UTEC and wideband feeding off only the ECU power wire, I had some really bad misfire issues (but all the time).
  #71
Interesting, ill change it ASAP. Ill get feed from the heated seats, lol thank god for those cuz iv ran out of 12v source lol
Old Jan 4, 2011 | 01:45 PM
  #72
You could always make yourself a small distribution block straight off the battery for 12v stuff inside the car. Looks pretty clean and works great.
Old Jan 4, 2011 | 04:00 PM
  #73
NiZMo1o1's Avatar
Also make sure your using the same size gauge wires when connecting the EU / J&S , whatever gauge the harness comes with , use the same gauge, dont try to go bigger either as a bigger guage (+) can surge and burn out the units.
Hopefully this is your last stop and kicking the gremlin out on your misfires.
Old Jan 4, 2011 | 07:05 PM
  #74
Yeah eventually ill make a little block for ground and another for 12v, but meh. for now the mess stays lol
I was actually planning on running a thick wire, to feed all the devices. Didnt think it would be an issue
Old Jan 5, 2011 | 09:26 AM
  #75
NiZMo1o1's Avatar
you dont want to do that ,the only time this applies is for Amps..
as long as the ECU gets a signal its good , if you go bigger guage this could cause issues , whatever gauge wire came off the harness, go with the same size , just solder them in and heat shrink wrap so it doesnt get expose to weather and you should be good, the grounds are usually the suspect for misfire or for any ecu not reading correctly
Old Jan 5, 2011 | 09:40 PM
  #76
So... improving the 12v sources did absolutely nothing. still missing. I wanna put in a new or newer crank pulley cuz mine has the rubber cracked all around. I am wondering if its wobbling a little bit at higher rpms and misaligning the teeth for the sensor.
Old Jan 6, 2011 | 03:21 AM
  #77
t6378tp's Avatar
Turbo 3.5
did you ever check the voltage while driving under load at high rpms doing so may save you alot of hassle
Old Jan 6, 2011 | 10:56 PM
  #78
Nah man not yet, for some reason Nissan Datascan dosnt wanna save logs. Havent really had time or felt like doing anything with the car. Prob wont do anything till the next holidays like spring break or something, I'm not going to keep wasting money, time, energy to get nothing in return. Looks like bad luck won this time.
Old Jan 7, 2011 | 03:32 AM
  #79
t6378tp's Avatar
Turbo 3.5
checking the voltage if you have a volt meter and a few feet of wire is free
SmokinMax02
18
Sep 11, 2015 12:25 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maxinout93
Aug 16, 2015 07:25 PM
acw
Aug 13, 2015 12:50 AM
