Though I'd share being there is not to many 7th gen times on here. It was pretty much the perfect conditions. 55 degrees and car weight with me in it was 3520. Tried like heck to get into the 13's but she would not do it. Another thing is it feels like something kicks in and drops the power down at about 85 mph. I know it supposed to do it but I just want to know how to shut it off!
Quote:
Thank you for sharing but just as a heads up so you don't get flamed, why don't you post more info like 60' 1/8 mile 1/8 mile trap 1/4 mile trap etc...Originally Posted by robsmax
Quote:
Time for you and dad to head to the track. Originally Posted by 7speed
Pretty quick. Car doesn't feel like low 14's. (dad owns one) ButI I'm still waiting to run against one.
OP: nice time!
Wait.... Forget the time Why hasn't anyone asked about the weight?? 3500 lbs w driver? 7th gens dont weight 3,3xxlbs. this might be one the fastest stock times for any model maxima. Good job cuh.
I guess if you run your car up the track 15 times in a day your bound to get some decent times. All my times were pretty much from 14.0 to 14.2. Only thing I did was leave the spare tire home. Tires were stock pressure with 91 octane. Thats what the dragstrip scale said so who knows. 3520 with driver and 3370 without. Also like I said it was only 50 to 55 degrees out, which I'm sure was the biggest help!
Quote:
Northern Illinois, checked the DA on 3 tracks (the rest are in central and southern) Byron, Cordova and Joliet and it looks to be in the 800-1100 range @ that temperature.Originally Posted by Rods03Max619
What state was this in anyway, and the elevation and were they giving out time sljps there...
OP, do you have a date, time and actual track for that run?
Quote:
Anyone have any clues on how to do this with a CVT? Lower tire pressure, OP, how was the launch, chirp, squeal... these might be irrelevant since i haven't a clue on CVT's.Originally Posted by joesae01max
get that 60ft down and you'll see 13's. BUT that does seem a bit off for a completely stock car. Nice job none the less.
Copied a couple time slips. The track was Tri State Raceway in Earlville IA on April 22.
The car hooked up pretty good. It made a short squeal but thats it. Not sure if its even another 10th to be had or not. What these cars really need is some cvt programming!
Quote:
60ft 2.278
1/8 9.189 mph 81.36
1/4 14.041 mph 100.55
Thanks guys I'll post em up.60ft 2.278
1/8 9.189 mph 81.36
hmmm very nice times
im still a little stunned tho ... my best trap on the old setup all motor was an 81 in the 8th too ... But i walk the new gen maxima's from the roll ...
traps are also around 100-99 ... but from a roll race at the track i put a good beating on the new maxima's
Quote:
i want and 09+ plus vq35de swap. better yet 6 speed sawp on an 09+Originally Posted by robsmax
i have a 2011 ...well my wife does...I took it tonight and it went 14.5 @ 97 2200ft da with carseats still in ...lol
all stock other than the stroller and the car seats.
Thats pretty good. How was your traction off the line? What was the temp?Originally Posted by mexi
i have a 2011 ...well my wife does...I took it tonight and it went 14.5 @ 97 2200ft da with carseats still in ...lol all stock other than the stroller and the car seats.
Problem with the new gen Max is the trans. is sluggish in shifting up to high rpms sometimes. If they had some aggressive downshifting they could give you a good run. Heck once mine is tacked out it can give my brothers 2011 Mustang GT a good run from like 40 to 90mph.Originally Posted by taz394
hmmm very nice times im still a little stunned tho ... my best trap on the old setup all motor was an 81 in the 8th too ... But i walk the new gen maxima's from the roll ...
I refuse to believe that 7th Gen weigh-in @ 33xx lbs as well.....I know for a fact they're weight without anyone inside is 3540 lbs, 3565 lbs (3.5 S, 3.5 SV)according to a magazine publication I was reading and this:
http://www.nissanusa.com/maxima/specifications.html
My 5.5th Gen is a 3320 lbs beast not that 7th Gen ,....the best thing with the 2009-12 is that freaking 290 hp VQ35 that's it!!! I sure SurraTT's swapped 7th gen motor into a 5.5 th gen Maxima (5.7 th Gen) will put him in the 12's even if he can't really launch in a 1/4 mile drag strip....and that's a legit setup I'm really interested in doing b4 200K miles get here!
Nice stock times.
My best stock time in my 2011 G37S Sedan was:
60' - 2.075
330 - 5.882
1/8 - 8.969
1/4 - 13.81 @ 101.80mph
60' - 2.075
330 - 5.882
1/8 - 8.969
Stock CVT doing 14 flat. WOW!!! Bro when your car runs these times you gotta get some videos. I have a modded up 6spd 6thgen and I had drag radials and still couldn't get there. But racing is more science than having a fast car.
I learned that from Aaron from NWP engenering. But good run
Quote:
the car is rated at low 14's, plenty have ran 14.2's n 3's i dont see why his is sooo unrealistic lol... we believe 14.0's stock from the 5.5's and nealoc's unbelievable 14.2 stock 4th gen lol... this is most certainly realisticOriginally Posted by kurt1
That's seems unrealistic being stock. But hay I might be wrong.
Good runs bro.. im so glad you are not in MD as we wouldve heard how much better our tracks are lol... ive seen where the most couple locals can squeeze out was 14.2, weather definately helped... what was the tire PSI if you remember?Originally Posted by robsmax
Copied a couple time slips. The track was Tri State Raceway in Earlville IA on April 22. The car hooked up pretty good. It made a short squeal but thats it. Not sure if its even another 10th to be had or not. What these cars really need is some cvt programming!
seems normal to me... its 300hp and the cvt (**** u cvt's you belong in eco cars n scooters!) keeps revs in the power band so naturally it should be slightly quicker than stock manual 5.5 gen. i know its porkier but the 40 horse advantage and cvt helps
Quote:
doubt there is 40 extra to the wheels... the 5.5's still somehow has the advantage but its definitely depending on the driver in the 5.5Originally Posted by carsnwomen91
Quote:
nah at the crank and rough estimate. 5.5 is lighter but then again i think its the cvt keeping a constant power bandOriginally Posted by Grand_hustle17
edit, 7th gen is 290hp 5.5 was rated at 255hp but i dunno whether that was under the older sae standards
The 255hp number for the A33b was the old standard, on top of that it was a bogus number. The 5.5 gen max, bone stock would dyno between 200-210whp on a Dynojet 248c (internet dyno) which put it on par with the 240hp (rated) Altima 3.5SE.Originally Posted by carsnwomen91
nah at the crank and rough estimate. 5.5 is lighter but then again i think its the cvt keeping a constant power bandedit, 7th gen is 290hp 5.5 was rated at 255hp but i dunno whether that was under the older sae standards
I am not familiar with the programming of the A35 CVT but I bet it could be improved with software. I would say a properly setup CVT would run all over a manual trans or conventional auto trans car. Perhaps not as fun to drive on the street but better potential on the track, and more consistent.
Good job on that run, I know a tiny number of A33Bs have claimed stock times that low but I would say that trap speed is very good. Shed some weight next time and see what you can get.
My friend and I also concluded that the CVT and weight are the issues with the 7th gen. If it had a 6speed like the 6th gen it would obliterate.
This is my 4th gen. OBX V2 headers vs a stock 7th gen. It was pretty close. Times weren't in the 14's but we are also at almost 5000ft.
FWIW, those times are totally believable to me. My 07 ran 14.5s stock. My buddy's '10 ran 14.2 @ 99.8 with nothing done. He swears that his '12 Max is quicker.
I posted up a method of shifting that many have gone on to try successfully. I found that mine would lay over around 75 mph, so after trying many methods of shifting, found that at the speed my motor would seem to pull no longer (75 - 80 mph), throw it into manual mode and let the computer shift the car itself. This method worked repeatedly time after time. I don't know how well it would work on the new max but I guess it's worth a try.
