Im pissed!
Old Feb 24, 2003 | 04:28 PM
maximase86's Avatar
I love lamp.
Im ****ed
Alright, I've done a few things over the weekend. Clean the car, installed a cone filter. Also over the past 2 weeks, I have been stepping my car down from 92 octane fuel. So the first week I ran 89 fuel. Car ran fine, just dandy. Saturday I stepped down to 87 octane. Well everything seemed fine. So I today, I'm driving, and since its warm out, I have the heater off, and all the windows down. The engine tends to run hotter...usually in the second half of the gauge, but it will never pass the tick mark before H. Well, get to the college, and have the car in second, the engine rpm's are about 1200-1500 and the engine starts knocking like a diesel. It clears at about 2k, but if I give it more gas, you can faintly hear it. I haven't notice knocking when the engine is cold though, but I will test it to make sure. Here are my guesses. 1. My car doesn't want to run 87 octane at all. 2. I need a tune up (I highly doubt, since its only been about a year since my last tune up, and I don't have any hesitation. 3. My timing is off just a tad, 4. When the engine is hot, the intake is sucking up a lot of hot air and causing detonation. Anyway, for those who have done the intake, what have you guys done to fix this issue? I'm think of going back up to 89 or 92 octane to see what I get...probably starting with 89 first. Then I'm probably gonna have to get cracking on making a CAI, since I don't want to but the stock airbox back on or even making a heatshield with sheet metal.
S
Old Feb 24, 2003 | 06:15 PM
Charles Bisel
I responded to your problem at the club.
-C-
Old Feb 24, 2003 | 11:07 PM
dr.disc's Avatar
-C-
Running excessive octane builds up carbon deposits in the combustion chamber, especially on top of the pistons. When you run lower octane afterwards, the carbon heats up excessively and is still glowing hot and causes predetonation before the spark plug fires.
You also said you have the timing off. That is something to look at for sure. Set it to spec.
Chevron makes a carbon deposit cleaner, which is in dilute form in their fuel injector cleaner, but which can be bought in higher concentration to clean up engines. It is called Techron. It is pretty good stuff.
What plugs are you running? I could use 87 octane with NGKs (which Nissan recommends) but not with other plugs I tried. I run NGK plugs, Nissan wires, Nissan cap and rotor, and stock timing without problem on 87 octane. I have trouble when I depart from this line up of ignition parts.
Old Feb 25, 2003 | 08:24 AM
max95q's Avatar
This is what Im thinking of doing if I install my cone filter. Im going to get a heater duct and run it from the front of the car to the cone filter so it gets more cold air in than hot. About the engine thing try to atleast stick with 89 if knocking with 87. I never use 87 the lowest is 89 if the mid is 90 or 91 Ill use that. Especially since prices are so high now I had to stop with the more expensive stuff.
Old Feb 25, 2003 | 08:27 AM
max95q's Avatar
Had to change your subject try to refrain from the foul language even though you feel it.
Old Feb 25, 2003 | 09:12 AM
max95q's Avatar
-C-
Is the club working? I got something saying the archives arent avail.
Old Feb 25, 2003 | 10:08 AM
maximase86's Avatar
I love lamp.
I run NGK Resistor plugs. I'm not running NGK cap rotor, or wires though :\. I'm going to step up to 89 or go back to 92. I had an engine vac done back in August to remove carbon buildup. Probably need to run some techron though anyway.
S
Old Feb 25, 2003 | 01:30 PM
dr.disc's Avatar
S
Unless you want to run a dremel tool or other wire brush on those pistons and valves, Techron is the only way to get at it I know of.
Old Feb 25, 2003 | 01:37 PM
maximase86's Avatar
I love lamp.
Its a nice little system they have. They hook your motor up to motor vac machine and the pump heavy concentrated solvent through the motor for about an hour. I think they actually use techron, but I'd have to check with them. After that, they flush out the solvent and ba'am your set. Gets everything nice and clean.
S
Old Feb 25, 2003 | 01:41 PM
Charles Bisel
Yeah, the club is working perfectly well. I'm surprised you had trouble accessing the archives, I can't remember the last time I had a problem with the Yahoo club, or any club on Yahoo for that matter. Now maxima.org, that's a whole other story. I usually have trouble reading the posts everyday.
-C-
Old Feb 25, 2003 | 02:00 PM
dr.disc's Avatar
S
Very, very cool. I had no idea anyone did that. What does it cost?
Old Feb 25, 2003 | 02:32 PM
maximase86's Avatar
I love lamp.
About $120. It cleans everything including the fuel injectors. My car was running really nice after that was done. I think its worth the money.
S
Old Feb 25, 2003 | 10:24 PM
max95q's Avatar
-C-
Yeah maxima.org is known for the probs, Hopefully once things get situated here it might run better. The admin and some of the moderators are debating the server issues to make it to where we wont have any problems at all, and if so then a specific person can just fix it right then and there instead of having to call to get the server back up.
magneto112
Sep 10, 2015 12:52 AM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 9, 2015 11:50 AM
kratz74
Dec 14, 2000 11:36 AM
ericdwong
Sep 24, 2000 04:20 PM
