Max Won't Start
Old Mar 27, 2003 | 03:33 AM
image1's Avatar
Max Won't Start
Hello fellow Maxima owners,
My Max won't start. I took it to the car wash and washed off the engine. After I finished, the car would not stay running unless I keep my foot on the gas pedal. I got the car home with no problem. The next morning I went to start it up it idled very bad and acted like it was going to shut off. I decided to drive my other car to work. Later on in the day I tried to start it again and it will not start. I have bought a new coil, distributer cap and rotor, and new plug wires. The car tries to run but shuts off. Does anyone know what else I might need to check before I tow it to the shop?
Old Mar 27, 2003 | 04:55 AM
Charles Bisel
You've got to be extremely careful when you wash the engine compartment, there are a ton of sensors that could have been damaged as a result. I'd check the computer codes and see if you do have any bad sensors, that's what I would assume if the problem occured right after you washed the engine compartment. And the worst part is that most of the sensors are really expensive for this car.
-C-
Old Mar 31, 2003 | 10:02 AM
Convergys's Avatar
Also, could be the Alternator is dead...
Happened with me as well. It will start only if it is jumped... then if it stops.. It will NOT start again.... chances are the alternator is dead
Old Mar 31, 2003 | 12:56 PM
maximase86's Avatar
I love lamp.
I would also check the MAF sensor, and the electrical harnesses for the fuel injection, it could be you got some water in those.
S
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
02PearlSE
Oct 7, 2015 02:12 AM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
