Trunk pop and spring probs?
I recently got fed up with my trunk pop not working correctly, plus i need it to work right so i can hook it up to me keyless/alarm, my problem was 1) the pop button would click, but rarely pop the trunk, to fix this, pop the trunk and look at the latch under the deck lid, there will be a little black tab, what i did was put a small piece of hose that fit snuggly right over it, my problem was that the actuator had to much clearence using the hose as a shim seemed to fix my problem. Now for the second problem, when i would pop my trunk it would not spring open like it was supposed to, to fix this i looked underneath the deck lid (right under where the stock alarm/keyless brains are) those long metal rods are springs, i wraped some good strong wire around the far left end of the two rods, there was originaly a clip there that held them together to allow the trunk to spring open...using the wire just acts as a makeshift clip. thought some of you may have had this same problem, so i figured id post how i fix my little "max problems". late, Kenneth
Re: Trunk pop and spring probs?
S
Re: Re: Trunk pop and spring probs?
Originally posted by maximase86
Well, when you pop the trunk, it's meant to spring up a little, not open all the way. Either way, what you did usually does the trick.
S
S
Re: Re: Re: Trunk pop and spring probs?
ok, so its not supposed to spring up all the way...my bad.but honestly..what would you rather have on your car??
S
REDinLV
10-18-2015 05:31 AM
MaxLvr21
10-17-2015 12:11 PM
