nitrous yes or no????
Old Aug 8, 2002 | 05:10 PM
Jon610's Avatar
i know there is alot out there about the stuff. but i want to know the truth about my situation. i have a 93 gxe with 157,000 miles. i have the tranny cooler and colder plugs. so i am ready to go for a small shot. but should i do it??? am i going to hurt my motor?? what brand should i get??? wet or dry??? thanks for your time. jonathan
Old Aug 8, 2002 | 05:21 PM
pearl93max's Avatar
A motor AND tranny in great condition can with stand abround a 100 shot of nawz. You just need to evauate the condition of both motor and trany....compresson checks, slipping through gears, ect...Also remember the age of you car and drive trane too.
I would got with wet kit from Zex...I believe they make a kit for our max.
Old Aug 8, 2002 | 07:54 PM
male's Avatar
You are asking for trouble. YEs our cars are notorious for high milage reliability, but that is on stock parts, with well maintained, driven "nicely" (no neutral drops please!" At 160K, I would really be hesitant to push the limits as NOS will. With an aoutomatic such as ours, which isn't known to be a bulletproof trans, I would not suggest it dude. Wait until you have the loot to buy another ride (5-spd SE maybe) or an extra trans and engine before you go juicing it. Just my opinion, Iv'e seen more than one person toast a motor on even mild NOS shots. NOS need more fuel or you'll detonate and eat pistons/rings.
Old Aug 9, 2002 | 02:44 AM
Dummy's Avatar
id go with a 35-50 shot... and a fuel pump upgrade.
Old Aug 9, 2002 | 05:27 AM
nismo1989's Avatar
hmmmm... I have a 5spd, obviously, and have 195K miles. I use Zex 75hp system. Something is always breaking on my car anyway, so the nitrous doesn't seem to present any sort of problem. I wouldn't put it on an auto, though... MHO
Old Aug 9, 2002 | 08:19 AM
Nismo87SE's Avatar
Re: nitrous yes or no????
I recommend the JWT n2o kit. Its expensive but it is the best way to run n2o, without having to make a direct-port kit. Here is the info http://www.jimwolftechnology.com/nitrous.htm. It is tested and proven to make the claimed or more power. For the 100 shot you'd have to get a high flow fuel pump (walbro or Z32TT) and 370cc injectors (Z32TT or Q45). The 50shot is fine with stock injectors/fuel pump.
Old Aug 9, 2002 | 08:39 AM
EdgeProductions's Avatar
I agree with Nismo87 I have the JWT kit minus the nitrous bottle and it is made to work with the stock system and only engage at WOT after 2k RPMS. If not theat then I would reccommend the Venom digitally controlled nitrous system if you are a professional or know someone that is and can set it up properly, both run around $1500 for the setup but are worth it is you do track racing!
Jared
Old Aug 9, 2002 | 02:46 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: nitrous yes or no????
i've considered getting the module added on to the upgraded ECU. If anything I would wait until my tranny is rebuilt/fortified. I wouldn't worry too much about the motor with only a 50 shot (which is what i'd go with)
Old Aug 9, 2002 | 03:15 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
on older cars injectors and fuel pumps tend to die as well......compression tests and all that are fine but when your out there juicing and #3 and 5 injectors craps out or the pump dies..... :: IMO popping nitrous in high milage car is not the wisest thing to do.
Old Aug 9, 2002 | 09:12 PM
Nismo87SE's Avatar
Almost better than a turbo
Old Aug 11, 2002 | 03:30 PM
Jon610's Avatar
bump
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
