lights
I just changed the bulbs on my max the blinker ones in the bumper they used to be orange not there hyper whites also changed the ones in the corners but i figured that ill just get clear corners now and then switch them when i get the new max. But I called up this place called ATV ( dont know if its only in NY) but they said $75 for piaa hyper whites for the head lights and like $30 for the clear corners. Im pretty sure that $30 was for the lense and not just the bulb
But is $75 too much for hyper whites or are the ones for like $20 just garbage ones.
Do you know off the top of your head what the bulb numbers are for the blinkers and the small(not the big) orange bulb in the corners? If you don't it's ok.
i unscrewed the oranged small ones
But i can get the buld if the number is on it also why not just get clear corners. What year style do you have. also where did you get those hyper whites from are the kinda blue?
Re: i unscrewed the oranged small ones
You can get the head lights by e-mailing calvinwch@yahoo.com he is the guy I bought mine from. I bought them for $25 shipped. I suggest you get the higher wattage bulbs and get the wire harness upgrade later. I haven't gotten one yet but i am planning on getting one.
I got my PIAAs from one of the other members on the board for $50. So far, I have been pleased with the brightness and throw. As I stated in another post, I am going to change the corners, side markers, turn signals, taillights, reverse lamps, and step lights. So far, I am looking at Polarg, Hiper, and PIAA. But I am open to look at other brands.
I have Xenon Crystal Bulbs from Eurolite. They were only $20 for the pair and they are awesome. I have changed the cornering bulbs with the same kind from Eurolite (1157). I think that small bulb that you were asking about is a 194, but I am not sure.
Some Advice...
Headlights -- 9004
Cornering (Large) -- 1157
Side Corner (small) -- 194
Turn Signals -- 1156
If you have, or plan on getting higher wattage bulbs, it is HIGHLY Recommended that you get the Upgrade Wiring Harness. I had the APC Plasma White Xenons in for about 6 months until the continued use of them completely fried my factory wiring harness. They will melt the harnesses and the wiring. Also, Higher wattage bulbs will not run at full brightness without the upgrade harness. Save yourself the trouble now, and invest in the upgrade harness. I have also Xenon 194s in all four doors and my guages.
APC Wiring Harness
https://maxima.org/forums/showthread...threadid=20233
[Edited by DaBoxGTI on 02-07-2001 at 01:14 AM]
APC Wiring Harness
I've changed all my lights to hyperwhites and my rear stop bulbs to LEDs, you're looking at about $100 or so for the lights.
194 x 4 - step lights
194 x 4 - dash lights
194 x 2 - cornering lights
1157 x 4 rear stop leds
1156 x 4 - front and rear turn signals
1156 x 2 - rear backup lights
so you're looking at about 20 bulbs at say $5.00 each, it'll be about $100
[Edited by ngthing on 02-07-2001 at 01:45 AM]
I didnt pay that much.,..
194 x 10 @ $5/pair
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
$61 w/o LEDs -- How do the LEDs look? Arent they facing sideways when installed? $61 is still a lot for lighs, but I think its worth it and worth the time.
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
Re: I didnt pay that much.,..
Originally posted by DaBoxGTI
194 x 10 @ $5/pair
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
194 x 10 @ $5/pair
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
The LEDs I bought more for saftey than for looks. They are darker than halogens, but they light up instantly, plus, they'll never burn out
194 x 10 @ $5/pair
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
194 x 10 @ $5/pair
1157 x 2 @ $10/pr
1156 x 6 @ $8/pr
Re: Some Advice...
Headlights -- 9004
If you have, or plan on getting higher wattage bulbs, it is HIGHLY Recommended that you get the Upgrade Wiring Harness....
Headlights -- 9004
Originally posted by roman
Next week I am going to do the same thing you did and replace all the bulbs with hyperwhites. Right now I am using Hyper Industries head bulbs(9004). These cost about $25 a pair and look great. I use the overwattage ones...I think they are 85/100 watts. I would recommend them to you.
Those overwattage bulbs are going to slowly melt away your socket...............
Re: Re: Some Advice...
Originally posted by laserjet
Okay, but the numbers above are for the stock bulbs that don't require a harness upgrade, right? I just got my clear corners and I am thinking I can just use the big bulbs that are in the old corner lenses and buy some amber 194's, is that correct?
You should also check out Craig B's website for the cornering lamp rewires (1 and 2). They're pretty neat if you have a solder (and maybe some additional wires) at your disposal.
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
