limp home mode
Old Aug 13, 2003 | 03:08 PM
mtcookson's Avatar
limp home mode
what all can cause the ecu to go into this mode? can a bad o2 sensor cause this?
Old Aug 13, 2003 | 10:45 PM
94MAXGXE
FSM calls it the Fail Safe System. Looks like the ECM itself, the Camshaft Position Sensor, or the MAF.
Old Aug 14, 2003 | 02:00 AM
Aaron92SE's Avatar
NWP Engineering.com
Re: limp home mode
I've only been in this mode once. The reason for the ECU engaging fail safe mode is too much wheel spin and other problems. I've done a burnout in water and it didn't engage fail safe mode, so I dunno. But I had my o2 sensor short out b/c the wires got pinched on a metal lip RIGHT next to the sensor. This shorted it out and immediatly went into fail safe mode.
On my VE, there is a metal lip close to the o2 sensor. Check that just to make sure it's just being pinch. If it is being pinched, then check your ENG CONT fuse in the fuse panel. Mine blew at the same time as my o2 sensor shorting out.
Old Aug 14, 2003 | 05:40 AM
89sks's Avatar
Mine did it when after I changed my timing belt I forgot to plug in the MAF harness that I undid to get to the lower radiator hose. I thought I had ruined the engine when I first cranked it! I was sweating bullets!
Old Aug 20, 2003 | 09:12 PM
mtcookson's Avatar
could a bad throttle position sensor do it?
Old Aug 23, 2003 | 02:55 PM
mtcookson's Avatar
how about the ecu not reading the ignition coil correctly.
when i do the real time diagnostics i get a ignition coil problem. i think it has something to do with the msd ignition box that is on there. i'm going to unhook it and see if something changes but knowing my luck it won't help.
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
