funny noise from engine
Old Sep 27, 2003 | 10:12 PM
Nmax92's Avatar
I'm hearing a noise from the engine when I'm driving. it's hard to explain, but I'll try my best to. The noise sounds like something fluttering only when I'm driving. If I put the car in (park) and rev the engine I don't hear it. I changed my muffler and extension pipe ( the one between the muffler and the Cat Converter).
I've heard other maximas on the road with that same noise. Does any one know what it is and how to fix it? I don't like hearing foreign noises muffling my sweet VE.
P.S. it's not the VTC
Old Sep 27, 2003 | 10:17 PM
AscendantMax's Avatar
fluttering? you sure some plastic bag didn't caught up under there or something?
Old Sep 27, 2003 | 10:31 PM
Cliff Clavin's Avatar
Way out West
possible problem with your y-pipe (flex section going bad) or even a manifold stud is broken.
Just guesses...
Matt93SE's Avatar
STFU n00b!
probably exhaust studs. check your manifolds and see if you've got any missing.
Old Sep 27, 2003 | 10:50 PM
i thought broken studs would create a hissing noise instead of a flutter
Old Sep 28, 2003 | 09:52 AM
Nmax92's Avatar
I wish it was a plastic bag Fosagte. I'll check out the studs and give you guys an update. Thanks. There is no place like the .ORG
Old Sep 28, 2003 | 09:54 AM
Matt93SE's Avatar
STFU n00b!
broken studs can create all kinds of different noises, depending on where they are. mine actually ticks like a bad lifter, and I can see it when it does it.
if the manifold warps enough, the gasket will start flapping around, producing a fluttering sound. if it gets really bad, then it'll start hissing as air is always coming out of the leaks.
Old Sep 28, 2003 | 10:12 AM
oh ok, thanks for clearing that up
Old Oct 2, 2003 | 10:56 PM
Nmax92's Avatar
Guys, you won't believe what the noise was!!
When I checked under the hood, I had the car running. I revved the engine and saw some exhaust shoot out near the EGR valve. To my suprise, that big nut that connect the 1/2" thick pipe to the EGR was off. Don't ask me how that, but that was the problem. So I tightened it real tight and now, my sweet sounding VE is BACK !!! Praise the Maxima Gods
Old Oct 3, 2003 | 02:56 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i hate it when dumb things like that go wrong. however its a relief that it wasnt anything major !
seesole
Sep 14, 2015 12:38 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
