Boosting
Old 01-07-2005, 07:15 PM
93MaxMurf's Avatar
Boosting
Boosting a '93 VG, worth it or no?
93MaxMurf is offline
Old 01-07-2005, 07:54 PM
4dscPat's Avatar
The only way to really bost a VG is to get a z31 (pre-90) 300zx turbo engine. It's the same engine except turbocarged. You could also put on all the turbo gadetry from the 300zx onto your engine, but both ways require some custom work.
4dscPat is offline
Old 01-07-2005, 10:15 PM
mtcookson's Avatar
imo... very worth it... but i'm a maxima nut so it just depends on how much work you're ready to put into it.
mtcookson is offline
Old 01-07-2005, 10:30 PM
Maxzilla91's Avatar
do u need to rip out the z31 ECU to go with it as well? any need for rewiring of anything? and i'm assuming the stock auto trans won't be sufficient anymore would it?
Maxzilla91 is offline
Old 01-07-2005, 10:42 PM
mtcookson's Avatar
z31 ecu won't work, its an older design. you're best bet is to piggy back the stock one, tune it yourself with the zemulator or romulator, or you can send it in to jwt.
the auto tranny probably wouldn't last too long but you should be able to get it built to handle the power. just have to throw down quite a bit of money to do it.
Old 01-07-2005, 10:46 PM
kcidmil's Avatar
Still not as extreme as me wanting to stuff the new 3.5L in my car. Just waiting on the lottery... then I'll have all the money I need to get it done... LOL
"note" so I don't get my butt reamed for it . This swap is impossible without the funds, knowledge, and plain insanity needed. I just need the funds. Insanity and knowledge are readily available...
kcidmil is offline
Old 01-07-2005, 10:53 PM
mtcookson's Avatar
on top of that... the VQ35's don't seem to be all that strong... 350Z guys seem to be blowing engines all of the time. the VQ30's seem to be much stronger but nothing beats the VG30DETT (note: this would also take some crazy money to make work... and i'm going to do it sometime )
Old 01-07-2005, 10:57 PM
Maxzilla91's Avatar
gee.. the ECU part sounds like a lot of work. sorry for my ignorance, but how does "piggy backing" work?
Old 01-07-2005, 11:01 PM
kcidmil's Avatar
Having it reprogrammed is what he's getting at.
kcidmil is offline
Old 01-08-2005, 05:09 PM
mod or sell?
internetautomar's Avatar
Megasquirt
internetautomar is offline
Old 01-08-2005, 05:45 PM
subs1000w's Avatar
Megasquirt
im thinking about ussing that on my go kart
subs1000w is offline
Old 01-08-2005, 05:59 PM
mod or sell?
I'd use a carb on a go cart.
actually I have a teeny carb (I think it is) sitting on my desk
Old 01-08-2005, 06:02 PM
subs1000w's Avatar
it is carbed right now but i was driving it in the snow last night and i have to have it idle really high to keep it from dying plus its a ***** to start in the cold and it has electric start plus it needs to be adjusted every few months when the temp changes
Old 01-08-2005, 06:26 PM
boosted3rdgen's Avatar
I have most of the stuff you would need to turbo your VG (you need a fuel pump, T3 actuator or external wastegate (my plan was to run external) and some for of fuel management, plus you would need someone to make your piping unless you can do it yourself)
300ZX T3 turbo(very minimal shaft play) and DSM side mount intercooler
1G DSM blow off valve with vacuum line, Manual boost controller with an extra 10ft. of vacuum line to hook it or other misc. items up
300ZX turbo manifolds (heat painted black) crossover and downpipe with 02 sensor
87+ 300ZX Turbo side feed injectors
$600 and ill give you the maxima.org triple gauge pod loaded with autometer phantom gauges: boost, trans. temp and A/F ratio
pm me if interested
boosted3rdgen is offline
Old 01-08-2005, 06:28 PM
obviously i cant post pics, perhaps something is wrong with my host or the site, maybe someone could search and find the FS thread i posted a while back
Old 01-08-2005, 09:15 PM
93MaxMurf's Avatar
would it be possible to drop a 90+ twin-turbo engine into the max?
Old 01-08-2005, 09:29 PM
Ninty-two-se's Avatar
Not really... Thats the vg30dett motor mentioned earlier... its just too big to fit. It could be done with lots of time and or money... might as well just get the 300zx and have rwd.
Ninty-two-se is offline
litch
123
01-04-2024 07:01 PM
James92SE
142
01-02-2024 09:23 AM
aw11power
10-10-2021 04:57 AM
MichMaxFan
09-30-2015 09:18 AM
hozay99
09-19-2015 10:20 PM
Quick Reply: Boosting
