Power Windows
Old Jan 29, 2005 | 11:27 AM
MAXI's Avatar
Power Windows
My front passenger & both rear windows are not rolling down when using the master switch from the driver side but i can roll them up. All windows works fine using the individual switches.
i don't think the master switch is the culprit but i could be wrong. isn't there a control "brain" box for the power windows under the steering column?
on a different question: what engine comes with the 98 Infiniti J30?
thanks,
Old Jan 29, 2005 | 11:40 AM
Josh's Avatar
Just to try the obvious first, did you have the push-button next to the controls on or off? i think the switch says Power on/off i could be mistaken i don't have my car with me, but anyway that controls whether you can control the other windows from the driverside controll.
Old Jan 29, 2005 | 12:32 PM
imported_Maxima_Mike's Avatar
I wanna say the last model year for the J30 was 97. I could be wrong though. It would be the VG30DE.
Old Jan 29, 2005 | 01:15 PM
spyhunter84's Avatar
No it doesnt the on/off is a saftey feature so you can turn off all the other switchs except the Drivers master switches, its a saftey feature for little kids
Old Jan 29, 2005 | 01:19 PM
and just to add i have this problem to time to time and i think i read some were that the circuit board goes bad http://maxima.theowensfamily.com/tsb/NTB92-007.pdf
Old Feb 4, 2005 | 10:51 AM
MAXI's Avatar
White relay box behind the stock alarm box...what is this?
[QUOTE=MAXI]My front passenger & both rear windows are not rolling down when using the master switch from the driver side but i can roll them up. All windows works fine using the individual switches.
i had to revive this thread, i still have this problem....i recently replaced a white box behind the alarm box under the left side of the steering....i hope that is the power window brain! The problem still exist. any ideas folks
Old Feb 4, 2005 | 11:03 AM
kholsclaw's Avatar
i had the exact same problem and replaced the master switch and it fixed it. I bought it off ebay for $20 including shipping. junkyard wanted $40.
Old Feb 4, 2005 | 11:11 AM
Wiking's Avatar
[QUOTE=MAXI]
Each door has a printed circ board =pcb with logic. The door button pressed: sends a low voltage request signal to the ctrl box. The box supplies 12V for that door win motor.
No continuous +12V supply goes to the doors.
If smtg overloads the electronic pcb's on the doors, the driver door [master] loses ctrl of them first.
What this all means is that maybe there is a short on these signal cables, pcb's on some doors. Needs only 20mA load/drain to short circuit & paralyse the system - water has flown in somewhere? ...oxidized contacts? ...bent cable?
see also: http://www.cardomain.com/memberpage/748507/13
Old Feb 6, 2005 | 07:47 PM
colinnwn's Avatar
I had this problem with the driver's door not controlling 2 of 3 other doors. I went through the FSM troubleshooting which revealed it was a bad drivers door switch. Replaced it and everything was fixed. However as Wiking said, it could be something as simple as corrosion at a connector.
As an aside, I busted open the old drivers door switch and found corrosion of the PCB tracks. If I was adventurous and didn't value my time, I could have possibly repaired it by cleaning and soldering copper wire over the corroded tracks.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
