Somethings broken here
Old Oct 23, 2005 | 12:46 PM
Sgibb's Avatar
I think i found the sound i was hearing but i dont know whats broken exactlly. here are pics of the driver side axle
Old Oct 23, 2005 | 12:51 PM
Greeny's Avatar
¯\(°_o)/¯
You have a broken cv boot...You can replace the boot but IMO you will be better off replacing the whole axle...
Old Oct 23, 2005 | 01:12 PM
Sgibb's Avatar
Doses someone have a write up for this.... i looked in stickies but couldnt find anything
Old Oct 23, 2005 | 01:16 PM
Harvs94max's Avatar
yeah replace the axle if its making noise
http://autozone.com/servlet/UiBroker...3d801f558b.jsp
Old Oct 23, 2005 | 01:26 PM
internetautomar's Avatar
mod or sell?
I sell brand new axles for the VG
Old Oct 24, 2005 | 10:55 PM
cwd14's Avatar
yeah replace that axle or it'll break on you eventually. it happened to me and it sucked a lot
Old Oct 25, 2005 | 01:16 AM
Wiking's Avatar
Thats the way to keep u donatin...
before phasta made pasta cabriolet, he wrote:
http://www.cardomain.com/ride/749143/8
Old Oct 25, 2005 | 08:19 AM
Jasovanni's Avatar
Expect the necessity for a full front suspension rebuild round 150k
Otherwise you're gonna be floating like a boat.
You know its CV when it creaks when you romp it....
J
Old Oct 25, 2005 | 10:58 AM
MrSector9's Avatar
umm you know it is a CV bad (axle not suspension part) when it clicks and clacks when you turn your wheels sharp ly :P
Old Oct 25, 2005 | 11:03 AM
Greeny's Avatar
¯\(°_o)/¯
Most of the time the boot breaks open like his did way before the cv ever starts clicking....
Old Oct 25, 2005 | 11:27 AM
Grace_Imports's Avatar
The CV boot is broken. That will eventually allow the grease to get slung out and dirt/contamination in. If it's an out joint then it will begin to click when turning. An inner joint will begin to give a vibration. If you ignore either one for too long they can come apart and you will be stranded as well as potentially damaging other components. You're better off (and it's easier) replacing the whole axle assembly. You can get away with (and it's cheaper) replacing the boot, but you have to catch it early before you get clicking. If you decide to go with just the boot, you need to make sure you clean the joint thoroughly and pack it well with the fresh grease that is supplied. Also, some of the clamps than come with the boot kits take a special tool. It's a very nasty job and I just prefer to replace the assembly. Avoid the speedy boot kits, they are worthless. Good Luck!
Old Oct 25, 2005 | 02:28 PM
MrSector9's Avatar
mygreen mr smartie pants notice i said CV and not the boot
Old Oct 25, 2005 | 02:33 PM
Greeny's Avatar
¯\(°_o)/¯
NANie NaNie!!!!
James92SE
142
Jan 2, 2024 09:23 AM
Forge277
Jun 13, 2016 09:26 PM
Noela
Sep 26, 2015 08:22 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
pears
Sep 18, 2015 05:25 AM
