When I brake my lights go out....
I got into my car and turned on the lights but the instrument panel wasn't lit. But when I pressed on the brake pedal they turned on. So every time I press the brake pedal they turn on along with the brake lights (front lights work fine). I changed the fuse but it blows it out.
Is it a short or what? Nissan will charge me $70 to check it! What to do?????? Thanks for the help!
Originally posted by Matt93GXE
Check the connectors inside your taillights. sounds like one of the sockets has melted and shorted some wires together.
there shouldn't be a relay on the brake lights- just a direct switch on/off. the only relays involved are the solenoid that releases the shifter when you press the brake on automatics... and even then, that's not REALLY a relay, but similar stuff.
Man mine were doing the exact opposite help me.All my dash lights corner lights and tail lights were going out so I replaced the fuse and then 2 minutes later they went out again.So I put a 15amp fuse in instead of a 10amp and havent had them go out in about a month now.Any suggestions?
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
