whats wrong with my baby
I have a problem folks. I have a 1993 SE which used to run perfect and beautifully. Lately when I'm driving, for me to actually accelerate i have to floor it all the way. if i dont, it stays at like 2500 rpms and then as soon as i floor it, it goes redline. What could be causing it to not make it want to go? Thanks in advance. Its probably something small and stupid but I'm lost. Thanks again
First things I would check are your throttle position sensor, and see if all your plug coils are working correctly.
problems like that on my old VG were from either non-firing spark plugs, or from a bad TPS... the VE is a different beast, but the TPS problem is still a factor. take a looksee and see what you can find.
Re: whats wrong with my baby
Re: Re: whats wrong with my baby
Originally posted by MaxSE
Do you feel hesitation when u go from stop to go?
WELL
SEEMS LIKE THE TRANNY TO M. MAYBE ITS DRASTIC THOUGH - BUT IT IS COMMON IN THESE TYPE CARS.... MY TRANNY ACTED LIKE THAT FOR A COUPLE MO BEFORE IT EXPOLEDED. I COULD GET IT UP TO 70 - BUT I HAD TO TRICK AROUND WITH THE PEDAL..ALMOST USE THE THROTTLE/PETAL AS A SHIFTER FOR THE CAR. I HOPE IT IS NOT THAT DRASTIC FOR YOU - BUT A POSSIBIITY. IF THAT IS THE CASE... YOUR BEST BET IS TO LOOK HARD AND GET THE CHEAPEST / BEST REBUILT AND JUST PAY SOMEONE TO SWAP THEM OUT FOR YOU. aNYTHING ELSE WILL TAKE AN ELONGATED TIME. And please - excusse capps. I just noticed...but I am not going to go back and retype now. take care.
Re: WELL
Re: Re: WELL
Originally posted by MaDMaX024
i have a manual if that post was directed towards me. hopefully it wasnt directed towards me BECAUSE i have a manual, i dont have the money for a new tranny yet. i'm saving...
regardless..it doesnt matter now
Yea i'm sorry to say it as well... but might be your tranny, my car had that same problem... with going but it was only my 1st gear that was gone... but don't take my advice.. just ask around a bit more... also try going to a transmission shop or nissan themselves and ask if they know what the problem is
when i was inspecting my engine after not being able to start it, i noticed a neon green plug without anything in it. if i can snag my friends digi cam i'll post what i'm talking about.
thanks.
ALSO GET A MANUAL
DUDE - The engine in this hot mama is much to boot. even now a days - it was a lil ahead of its time I think..there are so many sensors, fuses everywhere for maximum and optimal performance. many sounds, etc can be heard and its a number of things. A Hayes manual cost maybe 15 max at chief, autozone , etc. hook it up and you can learn a lot in there. again. there are dozens of differnt sensros in the car - etc. I washed my car once - the engine and was so thorough it blew a fuse on top of the tranny.... cost less than a buck for that fuse..but had to pay 60 to get the test done.... after thinking it was so much more than it is... so just get a book - many answers will then come your way. and keep posting here too - even couressy nissan refers me here more than answering my questions. Ha
Re: ALSO GET A MANUAL
Re: Re: Re: Re: WELL
Originally posted by spyhunter
it sounds to me like its a slipping clutch
Re: Re: Re: WELL
thanks
dude if you're having the tranny rebuilt, replace the clutch and t/o without question. its a ***** and a half to get off, you might as well do it while its off the car.
tranny time
Keep an eye out on ebay. there is usually always an auction going for a rebuilt guaranteed tranny for 400. anything under a grand is good..but I've never seen the auction go that high. Then pay someone 150.00 to swap them out - its a day job..but if they want the 1500.00 then they'll do it right nice for you. The reason your car doesn't start now..if you turn key and hear the starter try to start then disreguard...however if you turn the kep and nothing - as if no power...but the batterys fine - then look into the fuse that went out on my car..its on the transmission so you would not need to replace it if you swap out with a new rebuilt one... hope it helps.
Re: tranny time
any help would be appreciated, especially if it doesnt involve replacing the TPS.
thanks
Dude it may be something simple in the tranny to be replaced, without going through the rebuild bulls***. Sounds like to me that she isnt up shifting into third . I can throw up three possibilities without consulting the manuel right know. 1) the revolution sensor (not the speed sensor). 2) the solenoid pack may be going, or could be a bad external ground on the tranny that feeds the solenoid pack. I know mine was bad (real bad) corrosion all over it. The connector I'm talking about is located all the way on the drivers side and all the way in the front corner of the tranny, you need to search that area to find this one because its a little hidden. When I found mine I was cleaning it and then I said F-this and I cut the connector and soldered it right to the tab. 3) Possibly the inhibitor switch, but I dont think its this b/c its more typical for the tranny to fall out of gear when the inhibitor switch is not set correctly, so I'm not sure but I dont think it fits what your describing.
All of these are key components of the tranny that can be replaced without removing the tranny.
time for school lata
RPM
READ YOUR RPM'S. WHEN THEY ARE HIGHER THAN NORMAL - ANOTHER CLUE THAT ITS A TRANNY PROBLEM. RATHER IT NEEDS TO BE REBUILT OR SOEM SENSOR IS OUT... MY CAR CUISES AT 70 AND STAYS UNDER 2500 RPMS.... THATS ABOUT NORMAL. BEFORE MINE WENT OUT - GOING 70 AND THE RPM WOULD JUST STAY AT 4000 RPM'S THE WHOLE DRIVE... CHECK IT OUT
(excusse the caps..any problems with them and I hope you can - well - just get over it.)
i got it started. its not running good at all but no wierd smoke from the exhaust, but i did hear it coughing through the intake, and it stalled one me twice in the driveway. so i'm guessing its not the tranny. when i gave it some gas, it did exactly what it did when i start moving in first. i ordered a new throttle position sensor today, i'll install it tomorrow right after school.
any ideas for anything else? i put new bosch platinum spark plugs in before i tried starting it. i'm praying for the solution to be very simple.
thanks for all your help this far guys.
Re: regardless..it doesnt matter now
I had that problem last year with my Max...and I thought I was going to need a completely new trans but it turned out it was something connected to the tran or something like that...NOT HALF AS BAD! Trust me. You *might* not need a whole new tranny..could be something small too
just thought I'd make you feel a liiiiiittle better..but definitely get it checked out before you break down on a hilly road (like I did, with no shoulder to pull off on to....no fun!)
~Bernadette
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
~Bernadette
![kiss](https://maxima.org/forums/images/smilies/kiss.gif)
well
Thanks for the idea that I am putting fake ideas in his mind. scroll up youll see where I talk about many gizmos and sensors in this model max's engine. Unfortunately it can be the tranny sometimes...even though it is not always. But if you have the car for for an extended amount of time..many years..eventually it will be the tranny...You will not be able to know if the tranny could be it - until you get the car runnning kosher.... good luck to you and yous <max>>
I dont think its the tranny.
If your car has no power under 2500 rpm and power suddenly comes on after wards....then I say it must be the timing belt. If it hasnt been changed before or for a long time change it!
I had a similiar porblem with my auto, no power before 2000 rpm and then bang full power. After changing the timing belt which was totally off it was back to normal. Read my post "Just Changed the Timing Belt!"
Also check simple things such as spark plugs and it could even be a failed injector that might be contributing to the problem.
thanks again for all the help.
Forge277
06-13-2016 09:26 PM
bigfrank
10-01-2015 12:51 PM
