Allen head size on intake plenum
Old 11-28-2007, 05:16 PM
gapboi210's Avatar
Does anyone know what size the allen head is on the intake manifold so that i can get some allen head things for my ratchet on my way home.on my way home.
Sigh.... i hate buying tools from Wally world
gapboi210 is offline
Old 11-28-2007, 05:46 PM
ColombianMax's Avatar
6mm get the socket so you can be more efficient
ColombianMax is offline
Old 11-28-2007, 05:57 PM
gapboi210's Avatar
6mm. aight thanks
Old 11-28-2007, 06:05 PM
505max94se's Avatar
If you have a 6mm socket, a 6mm allen wrench, and don't want to buy a new socket, you can just cut about 3/4" piece off of the allen wrench and stick it in 6mm socket. If you're worried about it coming out of the socket, just tape them together...
505max94se is offline
Old 11-28-2007, 06:49 PM
gapboi210's Avatar
i don't have anything to cut it with at home. I'll just go buy a 6mm allen socket.
Old 11-28-2007, 07:52 PM
Jesus was a Zombie.
BenStoked's Avatar
on the bright side, you will have one now.
if you think you can justify spending a little more money, get the socket set.
then you will have it, and not have to spend time running to the store to buy one net time you need a different size.
BenStoked is offline
Old 11-28-2007, 11:23 PM
gapboi210's Avatar
turns out my tool kit had em already
Old 11-29-2007, 11:49 AM
Maxteca's Avatar
Don't the bolts strip or brake off alot of the time?
Maxteca is offline
Old 11-29-2007, 11:51 AM
They do strip and to do break from what I've noticed but not a lot if you ask me
Old 11-29-2007, 12:40 PM
gapboi210's Avatar
this is the second VG intake I have pulled. Just make sure that the allen is fully seated into the bolt. Use steady pressure untill the bolt breaks loose. Sometime's junk gets in the head of the bolts and if the allen isn't fully seated, they strip very easily. I've never heard of them breaking. They are not that tight. I reccomend hand tools on this one.
Old 11-29-2007, 01:16 PM
- Product of Maxima.org -
ustfdes's Avatar
just be careful, and good luck. and good luck. ;x
ustfdes is offline
Old 11-29-2007, 04:07 PM
gapboi210's Avatar
thanx its already done
VQ'ed
Forced Induction
02-29-2016 08:05 AM
mikeymouse1995
09-18-2015 06:42 AM
Mahmuth
09-17-2015 11:45 AM
meccanj98
09-16-2015 07:23 AM
Maxboy23
09-09-2015 10:37 AM
Quick Reply: Allen head size on intake plenum
