*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
im just gonna get the payment reversed and see if the other seller actually has the Tokicos
ok. I have a 1990 maxima. my battery died and replaced it. before it was just not holding a charge. now after replacing the battery none of my interior electronics work. my break lights don't work. I have to usethe shift lock to put it in gear. I have no clue what I did at all whatsoever. no blinkers either. and my keyless entry. windows. powers locks. basically nothing works at all. please please help
it starts to work after driving a little. for some reason i think it may be a loose or frayed wire in the main positive connection on the battery. im not sure. please help. also when i hit the breaks, SOMETIMES, after everything starts working again. everything in the car will blink sometimes radio gets shutoff. but the car starts everytime no problem. i just dont know. please leave info.
be glad your car is working right, to begin with.
This made me lol, yeah it's a nissan thing my old pulsar was the same, you have to lock the car after the drivers door is shut
The canister is located right under the battery/fuse box. You can follow the small vacuum hose from the Idle Air Control Valve down and it will lead you to the canister.
how do you take it out? i want to replace the vacuum hose to it because it is perished but it's stuck on and i can't get good leverage or a flat screwdriver to it where it is at the moment
can't get a box knife on there, and cut it off? if you are replacing the vac hose, anyway, it's the best way about it.
The trick is to lock the doors while the driver door is open. Then as you are closing the drivers door, you lift the door handle. Then when the door is closed you release the door handle. This will stop the mechanism.
Good luck
or if it's a GXE with a working keypad system press 9/0 after the door is shut
Complete dry fill including torque converter is close to 8 quarts(7 7/8 quarts)..but usually they will only take the full 8 quarts if the trans has been disassembled(rebuilt) and the t/c is new, or has been completely drained of old fluid...
What?! 8 quarts? On the manual transmission?! I think you're thinking of the automatic sir.
H
Have you checked your alternator/regulator yet? What about your fuse box wiring? Let's hear back if your still having problems or if not how you resolved your issues, Shiloh.
Sooooo, I got the transmission in, but one of the shifter linkage bolts wont go into the hole and tighten down. The linkage with the big flange that doesn't bolt onto the selector thing, it's the top bolt that wont go in. What does that second linkage do? Are both bolts required?
My 1990 maxima, auto, has 122k on it has just started making this grinding/whining noise at idle and it increases with revs. seems like it is coming from passenger side but I have been unable to get more specific than that. Belts seem to be tight? Here's a video
http://www.youtube.com/watch?v=0V6lwzHuPvo
pic? you talkin about the big plate thingy that attaches from the non-moving shift rod to the side of the tranny? should be 2 short bolts (one low down, one higher up) and one long bolt that reaches thru the block to the trans. i can take some demonstratory pictures on saturday if you can wait that long.
exhaust set up..
ok, im looking for an exhaust set up that sounds good with the vg30de engine.. i have a 89 nissan maxima se 5 spd.. i want it loud and deep but not raspy.. i was wondering, since my cat is pretty much dead, if i deleted cat for straight pipe, added two resonators and had my hks 4 inch echaust welded on, would that be raspy or no?? does any have a set up like this on their maxima?? or a set up that will give the sound im lookin for.. i want to use my hks muffler tip no matter what..
and it is vg30e, not vg30de; the "d" signifies "dohc", which the 3rd gen vg does not have.
it woudn't be horrible, i don't believe, but would change the sound. better or worse, not sure. I have a 24" resonator that the muffler shop put in, and no muffler and that is not raspy/loud. (not driving this way atm, be assured)
also, removal of the cat is illegal in most/all states, regardless of what the sate emissions checks are.
1996 max....
Hey guys I'm stumped. My car has been pumping water out into the reservoir and I can't figure out why. It's not running hot and the water that goes into the reservoir isn't hot either. It's like it's pumping air into the cooling system.
I thought there was a hole in the exhaust side of the manifold, so I put to bars stop leak in it. It seemed to work fine, it stopped the water loss for a while. Then, it blew out the radiator at the top. I put a new one in, got the air out of the system and it ran fine for a couple of days. Now, it won't start.
I'm completely out of ideas of what it could be......Any thoughts??
sometimes but not all the time when i turn on the car it makes a loud whining sound n i have to rev the car 1 good time to make it go awy, i was told it can be a loose belt or pulley.
i always have my music playing so i never noticed but yesterday i noticed when i turn left or right i hear like a humming/whining sound. its not clicks or knocks jus sounds like a weird humming mixed with whining. what can this be?
thanks in advance
thanks in advance
thanks in advance
thanks in advance
btw imma pm u something i need a lil help with, catalytic wise.
no you aren't either. all car-related questions stay on the forums. if you can ask me, you can ask everyone. i'm not answering sheeyit if it's in a pm
theres one more seller with Tokicos on Ebay, 3 weeks ago i emailed asking if they ACTUALLY have a set in stock. nothing. emailed again 2 weeks ago. nothing
gave up and just bought them. the ad says "All ebay auctions listed are items in stock"
we shall see if this is true
and as for the steering.. could be leaky seals inside the pump, could be that you put power steering fluid in there rather than dexron-III ATF. i swapped pumps and it got quieter, when i had that noise.
and
i sent a pm thinking u could of replied faster since u where online instead of waiting for someone to answer me 2 days laters.
Hi guys, im a noob here but i have a question about my 93 maxima. My car starts and runs fine but the electronics ie radio, wipers, lights ALL DONT WORK!!!!!!!!!! im freaking out because i have no ride to work, CAN U GUYS HELP A NOOB OUT, THANKS I APPRECIATE THE HELP!!
check all fuses, relays, and so on, also check the wires coming from the positive side of the battery, do you remember something strange happening before they all died?
