*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
sway bar endlinks, $1000? more like $50. unless the $cad is that weak, but I doubt it.
sway bar and bushings? no, there are plenty of people who have stock sways and aren't having problems.
perhaps he is trying to telling you that yours is FUBAR, but you missed it. it is, after all a nearly 20 year old car.
SHOULD you? sure. it'll make your ride that much better.
I saw some sway bars in the classifieds a couple of days ago.
another question, so far i have the timing belt, water pump, thermostat, crank angle sensor, and timing belt tensioner. he said that the pulley itself on the tensioner is probably fine, and to just get the actual tensioner. Napa had a $650 complete assembly, and a $50 tensioner so i grabbed the $50 one. does that sound right?
and i know its hard to tell without seeing the engine, but once he lifts it out is there really alot that can be bad inside?
what the hell is the "complete assembly"?
timing tensioner parts: tensioner pulley, spring, stud, nut, a couple of washers. that is it. aside from the tensioner pulley (the part that spins), we are talking about $10 of parts.
unless it's a timing CHAIN kit, for a VE (and $650 still sounds high)
i dunno, the part i got is like a round bearing kind of thing. the complete assembly had alot more to it. f
another thing is IIRC the guy told me to get a thermometer, but Napa said theres no such thing and said he probably meant thermostat. does that sound right?
and one more question, Napa tried all of the warehouses in Canada and nobody has a crank angle sensor, theyre going to call the factory then call me tomorrow. is it a really important part?
you sure he said thermometer? if so, are you SURE you trust him?
hmmm, good to know. if they cant find the crank angle sensor tomorrow i guess i have to skip it
i might have heard the guy wrong so its probably a thermostat. apparently all of the mad tyte JDM owners with Skylines and such go to him
VG Engine to VE Manual Trans
I have a 94 SE with a blown VE motor (snapped timing chain) and good 5-speed trans. I want to know if the VG motor will mount directly to the VE-style trans, which clutch part numbers to use, etc, necessary modifications, etc.
I know this information is somewhere in the forums but I can't find it...could somebody point me in the right direction?
(it would be cheaper,easier, AND quicker to go with a VE, again)
I put a multimeter in series on the two supply connectors at the battery to check for any shorts/power drain... one in very negligible; however the other jumps from 0.100, 0.135, .045, .100, etc... just keeps jumping around.. I'm thinking short?? these two connectors supply the alternator?? and only the alternator?? because if that is true I'm thinking about just eliminating it completely and throwing on a four gauge from the batt to alt... I've already disconnected the alt and still get the same issue. what exactly are these wires supplying??
thanks
update... I just put in a new batt because the one the prev owner had was undersized.. just checked alt at pep boys, and it passed.. but i'm getting voltage around 11.90 across the battery, and it seems to be decreasing.. going now to get the batt checked and alt again at a discount or napa
thanks
Thanks Benstoked. I know the VG is a drop in power, but I've owned both and like the torque curve/simplicity of that engine better. Here's another one for you...what about the VG33 engine from the later pathfinders/quest vans...do you know if they will bolt to anything a VG30 will? I'm mostly wondering about flywheel/crankshaft compatability with the manual maxima trans, as I believe the block is the same.
http://forums.maxima.org/3rd-generat...ap-really.html
thanks
thanks
are you sure the battery is good?
also, have to ask (because I have done it), is your multimeter set for sure to "DC" vs "AC"?
I am presuming you are checking amperage draw. if so, those are pretty negligible. I would suspect radio and clock memories, along with the normal this-that-and-the-other (alarm, keyless entry, etc.)
What exactly do those two gray connectors supply? is it only the alt? it's only one of the two gray connectors that shows jumps in amperage; need to find out what's on those circuits.
batt is a day old, but i switched it out anyways for another new one just incase. getting the alt and batt tested again tomorrow at a different shop, then i'll check the wiring and grounds.
main question is, what exactly do these two gray connectors on pos side of battery supply? are they just for the alt?
thanks
yea set to dc. but the thing is i checked for draw on the two supply connectors. when I'm checking the whole system for drain I go from the negative post to ground cable.. this was only looking at drain through each connector individually.
thanks
thanks
alternator wire is white, electrical system is white/red, going to the fuse box under the hood.
thanks. yea it's actually the white wire that's acting up. gets more than .035 amps and it's real erratic; jumps around. also tested resistance from batt positive terminal to alt pos, getting 25 ohms.
1) So is it possible to just completely eliminate that connector and run my own 4ga wire straight from batt to alt?
2) and does anyone have a complete wiring diagram of the charging system? I'm wondering exactly where the voltage regulator wires run too.
1) yes. just remember routing away from fans, exhhaust, etc. and leave slack for engine movement, it'll be good.
2) http://www.nicoclub.com/FSM/maxima/1994/
EL.pdf (page 21) is the one you want for this, what I used to find the wires.
I also suggest downloading them all, if you can.
Napa never called me back so im guessing they couldnt find any in Canada, i called the guy and he said hes not surprised but like you said its not that important of a part
still chasing my electrical/charging system problem...
had the headlights/wipers on and noticed after a while I was losing power. throttle was responding slow, bad acceleration. I turn off lights/headlights and the power comes back instantly. But it must not be charging my batt fast enough, car died and I had to jump it; started right up. went down the street, had to use my headlights and it died again; started instantly with a jump again..
still getting low voltage across the batt, right around 12v while idling. But I've checked the Alt twice and it passed; battery is brand new.. No shorts draining while the engine is off.
am I looking for a short, a ground, or can my alternator just be fooling the test??
those are definitely not 3rd gen wheels, kinda look like 5th gen wheels maybe. best way to find a set is to check local ads and find someone who got aftermarket rims and will sell their stocks cheap
They may know what model you could find them on (if they were an option).
thanks, capedcadaver benstoked and chrome91, i am a member on "maximas down under" and they say they are from a US car thats why i asked here, so i know what to ask for when i start looking
my Tokico struts should have been here this week, i just got a email from the Ebay seller saying that because the Tokicos were discontinued they dont have any in stock and can special order KYB struts for less and refund the difference, would KYB struts work with the 2" drop on Ksports?
then again, I am known as a douche, so
no, kyb won't last with a drop like that. not on a car that is driven more than onto a trailer.
tell them to get the tokicos, or full reimbursement, plus 10% for wrongful advertisement, or they get the negative feedback (that gets their panties in a wad).
plus the Ebay ad said 3 sets in stock
but even IF the KYB struts would work it would take them 2 weeks to get into the warehouse plus 2 weeks to ship out from there, so a month or more total. i found another seller with Tokicos but im going to ask if they actually have them in stock first lol
Ok, I started on my swap. I got the transmission out. I got the clutch, flywheel, and pressure plate out. But a mount broke on me and I can't continue until I get a new one. Below are pictures of said mount. Will an automatic max have one? Or is this a manual specific mount?
When other people get in my car (93 Maxima), they say they can smell gasoline.
When I have the hood popped open and I turn on the engine, even slightly walking up to the engine and your huffing fumes.
Carbon Monoxide .. - Kills brain cells.
Gas Fumes.. - Kills brain cells.. destroys your smelling senses. ((Explains why I dont smell gas when I get in my car but other people do.))
Am I getting high from driving my car and not even knowing it.
Is it my death machine to turn me into a 101 year old man without even turning 101..?
Im thinking about selling my maxima with 240k miles for $1300.
I mean.., I think it does leak oil or gasoline. What can I really do about that..
), or fix it.
Where are my fuel hoses? And also is my gas tank located right next to/part of the engine or in the back of the car?
(Because I got underneath the front of my car, and the bottom portion is wet with oil or fuel.. probably oil. Maybe the gas tank has a small hole in it..? Fuel hose has a hole in it..? )
It literally drips oil I believe in the front of the car. between the 2 front wheels.
especially fuel leaks
