*NOOBIES* The "I am new here,but have a question" thread..(post your questions here)
Old Aug 4, 2009 | 10:41 AM
  #3921
the roach's Avatar
plugs are all new all the coil pacs are good everything is firing good. i have a hard time thinking it would be an injector but i will pull the plugs off to check it out. wich temp sensor is for the ecu? i pulled the bigger one off and my fans come one plugg it in and they shut off the litle black one was dirty so i clean it made no differance, but my temp guage still barly moves. i also blead the air out of the cooling system and that made no differance. i might just hook up to a contant pull vacum supply and put an in-cab flow control in the line so i can adjust the fuel pressure in the cab.
what is the easiest way to install a new clutch? i know how to install one but i have never done it on this car and i dont work on much front wheel drive junk.
Old Aug 4, 2009 | 10:42 AM
  #3922
W00dface's Avatar
Originally Posted by BenStoked
please, phrase that in a form of a question...
and what do you mean, "one of the HT's are pretty knackered"?
(I get the 'knackered' part, I think, but HT?)
HT leads (high Tension) from the distributor to the spark plugs
Old Aug 4, 2009 | 10:56 AM
  #3923
CapedCadaver's Avatar
Call me Wookiee Goldberg
i see. that's not the same terminology that's typically used in the US (where probably 90% of this site's users are). we just call them "spark plug wires"
Old Aug 4, 2009 | 10:58 AM
  #3924
remove the front axle nuts and axles, unbolt the shifter and clutch stuff from the trans case, support the tranny from underneath then umbolt it from the block, unbolt the tranny mounts, then pull the tranny off.
Old Aug 4, 2009 | 11:04 AM
  #3925
the roach's Avatar
ok sweet thats what i was thinking just wanted to make sure, thank you
Old Aug 4, 2009 | 11:45 AM
  #3926
W00dface's Avatar
Ah, the terminology for most things is the same though
Anyone got any recomendations for a good set?
Old Aug 4, 2009 | 11:52 AM
  #3927
300zmax's Avatar
that sounds so easy
Old Aug 4, 2009 | 12:15 PM
  #3928
nissan-OEM from your dealer, or NGK should be good
Originally Posted by 300zmax
that sounds so easy
it is easy ..... about 6 weeks ago i dropped the trans and pulled the clutch and flywheel off my white 89 with the car parked ON GRASS, without removing the passenger-front wheel under 2 hours...
honestly the most annoying part is how long it takes the tranny to drain.
Old Aug 4, 2009 | 12:42 PM
  #3929
BenStoked's Avatar
Jesus was a Zombie.
wanna help me do a 5-speed swap?
Old Aug 4, 2009 | 12:48 PM
  #3930
on that other one you picked up recently? meh, not now that i'm working. not gonna burn vacation days just to work on a stinkin' cah.
Old Aug 5, 2009 | 06:59 AM
  #3931
W00dface's Avatar
So far with my 93 SE i have checked all the Vac hoses (one broke) given it a service (new sparks, oil etc) put on a RAM and taken out the Air con (we don't need it in the UK)
Now looking at moving the battery to the boot, tidying / polishing engine, red & white colour coding engine and turning interior red & white.
There are a couple of other things I am thinking of doing and have a couple of questions that someone might know the answer to (used search already )
First off, thinking of fitting a supercharger (esp now the air con is out of the way) anyone know if there is one that is easily swapable from another car? we have a good scrap yard near me so after a Turbo or ideally supercharger with as little hassle as poss.
the other thing I was thinking is that I now have a spare air con rad that may have use as an intercooler??? Looking at it, it may be a bit too restrictive of the air flow?
If anyone wants any air con components, then let me know
Old Aug 5, 2009 | 09:39 AM
  #3932
eh, you'll be the first to do a supercharger if you do it... but with the a/c gone i suppose you could run it off the old a/c belt. but due to space constraints nobody has ever done a supercharger on a air conditioned 3rd gen (or any other, for that matter)
all your air con stuff is for RHD tho isn't it?
Old Aug 5, 2009 | 04:10 PM
  #3933
W00dface's Avatar
It should be the same as the cars in the states.
Old Aug 5, 2009 | 04:19 PM
  #3934
compressor, yes. but the hoses and hardlines are different b/c the air con evaporator is always in front of the passenger seat (thus RHD has it on the left side. LHD on the right side), and i can only assume that the evap and its housing are a mirror image of the LHD versions.
here's a comparison pic
RHD the big air con hose goes by the radiator in front
LHD the big air con hose goes around the belt side of the engine
Old Aug 5, 2009 | 05:05 PM
  #3935
the roach's Avatar
ok somone help me out here i called courtesy nissan to try and order a new spring for my vtc and the guy had no idea what i was talking about. he told me my only option was to buy a new vtc lol. i am not sure he really new what he was talking about. dose anybody have a part number for this spring? or atleast a better place to try and find it?
Old Aug 5, 2009 | 06:22 PM
  #3936
13072-97E00
Old Aug 6, 2009 | 08:18 AM
  #3937
mitchxtoledo's Avatar
Good mornin' folks
I have some free time coming up with all this fun unemployment going on, and my 1992 Max GXE isn't getting any healthier. I have some minor power steering issues, exhaust questions, engine groans, and a few cosmetic bits I'd like to get patched up.
I wanted to ask the community of varying levels of experience for some advice on what sort of repair manual to get and whether or not to invest in a diagnostic tool so my car can communicate with me in a more meaningful way.
Here are the items that are in consideration for purchase:
1. 1992 NissMax Factory Service Manual (~$50 on eBay so far)
2. a Nissan consult interface (http://www.plmsdevelopments.com/consult_if.shtml -OR- http://www.blazt.biz/products/cable.php, $90-140)
I already possess a Chilton's manual for 3rd Gen Maximas, but it doesn't have the level of detail I might need or step-by-step procedures for particular areas I'd like to work on. How worthwhile are either of these, and can anyone provide anything else that would be an all-around smart purchase for taking down this work myself?
Also, I have the aspiration of replacing the exhaust system from the catalytic converter back, there seems to be a good amount of white smoke (just in puffs, not large clouds of it) pumping out the exhaust when the car first starts, which I don't recall being normal.
Old Aug 6, 2009 | 08:40 AM
  #3938
the roach's Avatar
13072-97E00
thanks for the info.
Old Aug 6, 2009 | 03:59 PM
  #3939
BenStoked's Avatar
Jesus was a Zombie.
Originally Posted by mitchxtoledo
Good mornin' folks
1)FSM:
http://forums.maxima.org/general-max...niti-fsms.html
2)Consult, from what I understand basically does this:
http://forums.maxima.org/4873104-post18.html
Old Aug 7, 2009 | 08:07 AM
  #3940
1)FSM:
Nissan/Infiniti FSMs
1) They only cover Maximas 1994 and up, two years ahead of my car's time. I'm sure I can manage with that info, but I may have to locate an actual hard copy of it.
2) The Consult is supposed to do more than read codes, it's supposed to be able to control the car's computer and can also give you readings on air flow, timing, the O2 sensor and the like.
This is all very useful, so thank you
Old Aug 7, 2009 | 09:51 AM
  #3941
MOST stuff on the 92 is the same as the 94. except the design of fuel injectors on a VG. now if you had a 89-91 car, then there would be quite a few more differences.
Old Aug 7, 2009 | 11:06 AM
  #3942
codyl1992's Avatar
stuck spark plugs
Hi everyone, I recently decided to replace my spark plugs as the car has 72000 miles on it and they are rated for 60000. I was able to remove all 6 boots quite easily but the spark plugs are stuck. (As far as I know, they've been in there for 16 years!). I couldn't get them to move even after soaking in WD40 overnight. I really don't want to strip the thread so I stopped trying.
I'm using a cheap ratchet and socket kit I got at autozone, so I'm thinking that if I get a longer ratchet I might be able to work them free. Is there anything I can do that would reduce the risk of stripping the nut on the spark plug or to make it easier to get them out, like a different oil to soak them in or something?
Old Aug 7, 2009 | 12:45 PM
  #3943
ghowar6's Avatar
2002 Maxima - Rich Flow -
I have a 2002 maxima & my wife was driving it on the freeway, she tried to accelerate to change lanes & it started sputtering & died. It would start but would only run for a few seconds then die again. I had it towed to my family mechanic. He can keep it going but the compluter hooked up to it will not tell him a problem... I had him change the plugs & clean the MAF but he still says it's running "rich" causing it to flood & die.... any sugestions...? Please post here or email me @: ghowar6@yahoo.com ... thanks in advance for any advise on this. I'm trying not to spend $1000 for the dealership to tell me I need to fix everything on the car...
Old Aug 7, 2009 | 12:47 PM
  #3944
chrome91's Avatar
wrong section, this is the 3rd gen 89-94 section
Old Aug 8, 2009 | 10:40 PM
  #3945
Zero_webb's Avatar
spark plugs fouling?
So my maxima's original engine's block cracked and i swapped it out for another VG that was sitting around the shop. but ever since then my car has been fouling out spark plugs like crazy. I can take the plugs out, clean them off with a rag and reinstall them, and the car runs like a top for a week or so before they foul out again. The plugs have been changed, distributor has been changed, oil changed, wires changed, even tried installing anti-foulers but nothing seems to stop it. someone suggested that the rings may be blown, but I really doubt it because of how well the car does between foulings. also had a suggestion that my fuel mixture may be too rich.... anyone know something that I don't?
Old Aug 10, 2009 | 03:14 PM
  #3946
seans90maxima's Avatar
Alright, so my sound system is messin up and i know nothing about electrical. When i turn on the stereo and turn the volume ****, the front right speaker crackles which leads me to believe its blown out. But if i leave it a certain volume there wont be any crackling but the sound will either come out of the front left or rear speakers, but it just randomly comes from different speakers which makes me think theres a short. Its the original bose stereo system and bose speakers.
Old Aug 10, 2009 | 03:54 PM
  #3947
BenStoked's Avatar
Jesus was a Zombie.
original Bose is an antiquated setup. many of the components go bad. sounds like yours is on it's way.
I would recommend a new head unit. if all the speakers work (even intermittently), you may be okay to reuse the speakers that are currently installed (I don't recommend it, but many other members seem to have success with this).
There are a few articles, and threads around here, detailing new stereo install, and speaker bypass.
if you go with an aftermarket head unit, I recommend (I would demand, if I could do such a thing), that you use a head unit wiring kit (such as the scosche, to name a brand), makes your life 100x easier, and it's only about $15.
Old Aug 10, 2009 | 04:37 PM
  #3948
Thanks, I'm planning on buying a new system when my budget allows it. Just seeing if theres a quick fix till i get a new system.
Old Aug 10, 2009 | 04:46 PM
  #3949
BenStoked's Avatar
Jesus was a Zombie.
well, speaker crackling, in the situation you describe, is typical of a dirty/worn potentiometer (volume ****). you may be able to take the radio out, and clean it, but I would not know how.
Old Aug 10, 2009 | 05:22 PM
  #3950
Alright, Thats such a hassle to take off everything to get to the stereo. but thanks for all the info. I'll try it.
Old Aug 11, 2009 | 04:53 PM
  #3951
getting the head unit out is only like 8 screws....
Old Aug 11, 2009 | 05:01 PM
  #3952
internetautomar's Avatar
mod or sell?
it's exactly 8 screws on a 89-91. 92-94 has 2 screws less.
of course that does not include the screws holding the radio onto the bracket.
Old Aug 11, 2009 | 05:12 PM
  #3953
jimbot18's Avatar
well i have a 93 se and i cant find a cold air intake for it does anyone have any idea were i can get one ?
Old Aug 11, 2009 | 05:18 PM
  #3954
mod or sell?
egay primarily.
Old Aug 11, 2009 | 05:30 PM
  #3955
jimbot18's Avatar
egay primarily.
what does that mean ?
Old Aug 11, 2009 | 05:35 PM
  #3956
egay = ebay + gay
Old Aug 11, 2009 | 05:40 PM
  #3957
jimbot18's Avatar
is ebay a bad idea for A COLD AIR INTAKE because no websight offer them which makes me think there not anywere to be found pluse i dont want to wast money on something that doesnt work or fit right
Old Aug 11, 2009 | 05:45 PM
  #3958
mod or sell?
IMO ebay is a bad idea for anything. but that is my opinion.
Old Aug 11, 2009 | 05:51 PM
  #3959
jimbot18's Avatar
i have looked at ebay and have see intakes for a 93 se but that the only place all over the web all well know sights say there are no intakes for that year and model at this time
Old Aug 11, 2009 | 06:03 PM
  #3960
you can get some pipes and elbow thingies yourself and make your own also. 3" i think.
