Exhaust Studs
Old 05-29-2008, 07:05 PM
  #41
1993-VG30E-GXE's Avatar
Originally Posted by Matt93SE
The studs don't break off because they're too weak. The studs are breaking off because they were installed improperly at the factory.
You're not supposed to bottom the stud out in the bottom of the hole OR butt the tapered shoulder against the side of the head. either of these actions will cause points of high stress in the bolt and will cause premature failure.
I'll scan the article I'm referring to when I get some time.
Or they may be breaking off because they are 16 years old and have become weak from age ie. wear and tear.
1993-VG30E-GXE is offline
Old 05-29-2008, 07:21 PM
  #42
goon9's Avatar
Makes sense. BUT there alot of other imports that just do not have that problem.
goon9 is offline
Old 05-29-2008, 07:41 PM
  #43
STFU n00b!
Matt93SE's Avatar
You just don't know when to stop arguing, do you?
they've been prone to breaking on these cars since they were NEW, not just the last few months. I replaced mine ten years ago and installed them properly and haven't had a problem since.
Matt93SE is offline
Old 05-29-2008, 07:45 PM
  #44
goon9's Avatar
He's the same dumb@*** that couldn't figure out how to drain coolant isn't he...
STUDS are not a wear and tear item. BRAKE PADS ARE.
goon9 is offline
Old 05-29-2008, 08:06 PM
  #45
Call me Wookiee Goldberg
CapedCadaver's Avatar
nor does he know how to stop making threads. I believe he made 21 threads in the 3rd forum alone in 35 days.
anyways how do you install them without them bottoming out during the tq-down process? by putting the short side in? (or was it already short-side in?.. hm i forget now)
CapedCadaver is offline
Old 05-29-2008, 08:33 PM
  #46
STFU n00b!
Matt93SE's Avatar
Yeah.. I thought the dumbarse was already handled. Guess I'm going to have to take care of him myself. :grumble:
edit... there. fixed.
short side of the stud is what was in from the factory. doesn't really matter either way since both sides are long enough to do either end of the job.
the torque required to screw the studs into the head is more than it takes to run the nuts down...
What I did was double-nut them and run them in using that, then remove the nuts, put the gasket and manifold on, then run the nuts down. voila.
my scanner **** itself tonight, but if you guys wanna see what I'm talking about, look for Carroll Smith's Engineer To Win. Go to page 142 in the threaded fasteners section. the figures of what NOT to do are exactly how the OEM studs are installed in the car.
Matt93SE is offline
Old 05-29-2008, 08:45 PM
  #47
your "stfu n00b" caption rings truer than ever haha.
that's how i installed mine. double nut, torque, remove nuts, install manifold, put nuts on with 5lbs less torque than the studs got. can you just... describe the factory method and let us picture it in our heads?
Old 05-29-2008, 09:07 PM
  #48
STFU n00b!
Matt93SE's Avatar
I dunno how the factory puts them in, but they run them in until the shoulder is seated against the head.
that creates a fracture-prone area at the shoulder, focusing all the stress on the weakest part of the stud... so when it breaks off, it breaks off just below the surface of the head- which is where I've seen the fracture point on every single one of the broken studs on a Maxima.
Simply a manufacturing mistake that costs everyone in the long run.
Matt93SE is offline
Old 05-29-2008, 09:17 PM
  #49
maybe it's that they run it down so far that the middle banded section gets jammed into the hole and is kinda tugging against the threaded part. the threaded part is long enough to win, and the rest of the stud just falls out b/c it's the only one with a place to go.
Old 05-29-2008, 09:46 PM
  #50
Wiking's Avatar
Originally Posted by MaxDude08
rea ding helps http://forums.maxima.org/showthread....88#post6435488
Wiking is offline
Old 05-31-2008, 08:34 AM
  #51
MaxDude08's Avatar
Thx very informatvie. What size bolts is eveyone using? Just called a dealership they want 9bucks per bolt.
MaxDude08 is offline
Old 05-31-2008, 08:44 AM
  #52
GAMERA30's Avatar
Location: Long Beach, CA is where i live. Queens NYC is always home.
I work as a tech in the " stealership" I used 350Z studs on mine ... work great
GAMERA30 is offline
Old 05-31-2008, 09:05 AM
  #53
MaxDude08's Avatar
Just found this for anyone else in need of bolts/gasket.
http://cgi.ebay.com/ebaymotors/_Car-...ayphotohosting
Old 05-31-2008, 09:28 AM
  #54
shoult's Avatar
Eighty bucks for one side is REALLY expensive!
When I did mine in 2003 all new hardware for both sides cost me $19 and change, a pair of exhaust manifold gaskets was under $30. This was all purchased locally at Nissan dealerships.
shoult is offline
Old 05-31-2008, 01:20 PM
  #55
MaxDude08's Avatar
I just called one up and they were going to charge $9.00 per bolt 34 for gasket
Old 05-31-2008, 02:39 PM
  #56
shoult's Avatar
Call a different one and NEVER call that one again!
shoult is offline
Old 05-31-2008, 03:38 PM
  #57
MaxDude08's Avatar
i bought the one from the link and asked to send 6more and he said thats cool.
Old 06-01-2008, 08:28 AM
  #58
GAMERA30's Avatar
I think I`m one of the lucky ones who ever had to do a regulator on my Max`s.
GAMERA30 is offline
Old 06-05-2008, 12:54 AM
  #59
tv4184's Avatar
The previous owner of my max had to fix a broken stud at around 109k. He broke 2 drill out bits before getting it out and his dad wasted about 700 on rebuilding the VTCs until he found out the real problem on the maxima.org.
The other things Nissan seemed to mess up on are some of the electrics and the foam on my dash is starting to expand at the vents.
tv4184 is offline
06-06-2017 02:01 PM
Justin Kroll
10-01-2015 07:03 PM
09maxshawn11
09-30-2015 10:28 AM
Socalstillen
09-26-2015 12:01 PM
dcam0326
09-26-2015 05:20 AM
Quick Reply: Exhaust Studs
