Car won't pass smog!!!!
Old Jun 10, 2008 | 10:34 PM
92MAX92's Avatar
My 92 max SE doesnt pass smog it passes emissions but he said i failed the vapor part or something they say i have a leak somewhere from the canister to the gas tank any ideas?
Old Jun 11, 2008 | 06:30 AM
crabapple's Avatar
Not sure what the canister is but I had to get a new gas cap a couple years ago to pass an inspection.
Also, I just replaced the breather hose which runs between the fuel neck and the gas tank because it was leaking. But in that case I didn't need an inspection because I could see the gas on the ground after filling up my tank and smell the fumes whether the tank was full or not.
Old Jun 11, 2008 | 06:32 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
2 ideas. either torn vac hoses under the hood, or a torn overflow tube up above the rear subframe where the tank filler neck is (torn overflow hose will leak upon using the automatic fillup at the gas station). there's 1 short vac hose out of the canister (which is DIRECTLY below the battery/relaybox btw) to a metal pipe, which leads to another rubber line back by the firewall, then there's those 2 other hoses (one medium diameter, one small diameter) leading to the intake manifold somewhere... dunno where they go to on a VE. and then there's a big fat one at the bottom that goes into the frame (i know, right?). also make sure that the bottom of the canister (or any part of it) isn't cracked or anything.
Old Jun 11, 2008 | 10:24 PM
CMax03's Avatar
perform a vacuum test on your canister, the rubber vacuum hoses and hard lines till you find you leak!
Old Jun 13, 2008 | 07:09 PM
92MAX92's Avatar
could this hose be the problem its not connected to anything its next to the hose from the canister to the intake manifold ?
<img src="">
Old Jun 14, 2008 | 07:51 PM
internetautomar's Avatar
mod or sell?
looks like the breather hose from the transmission
Old Jun 19, 2008 | 01:33 AM
92MAX92's Avatar
if its the breather hose from the transmission is it supposed to connected to anything?
Old Jun 19, 2008 | 06:07 AM
mod or sell?
nope
Old Jun 23, 2008 | 11:06 PM
92MAX92's Avatar
would gas vapors be running through the line connected to the egr valve because that hose was lose and cracking. when it failed smog because of vapors he said its one of the lines running from the canister or the canister itself and the line runs from the canister to the intake manifold then to the egr cylinoid then to the egr valve i know its confusing
<img src="">
Old Jun 24, 2008 | 05:34 AM
mod or sell?
No vapors should be running in any vacuum line. there are separate lines for the fuel vapors.
you may have failed because the line at the EGR wasn't working so it couldn't do it's job.
Old Jun 25, 2008 | 12:38 AM
CMax03's Avatar
Check your canister which is under the battery and check that all the lines are installed as per your FSM or vacuum diagram, and check them for conditionand operation, there maybe a checkvalve in that system as well refer to the FSM. Was your filters and oil changed b4 doing that emissions test? Are you burning oil? Fuel cap working properly?
Lakersallday24
Jun 16, 2019 01:35 AM
Btheman80
May 1, 2018 04:03 PM
Dasmith
Aug 25, 2015 10:15 PM
BobMax
Aug 15, 2015 12:35 PM
MaxStock
Aug 12, 2015 08:33 AM
