Equal Length Y-Pipe (w/vid)
Old Dec 16, 2008 | 05:02 PM
505max94se's Avatar
It has a WSP full 2.5" exhaust with a magnaflow muffler and an equal length Y-pipe. It sounds amazing and butt dyno tells me that it gained significant power through out the power band (unequal vs. equal length Y-pipe). With the equal length Y-pipe, it's ALOT quiter and it's not raspy at all like it was before. It has a much more refined sound. The sound reminds me of a inline 6 with a nice exhaust (i.e., supra, bmw). I think I fell in love with my Maxima again.
It was only backfiring slightly because the engine wasn't fully warmed up.
Old Dec 16, 2008 | 05:15 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds pretty mean..
Old Dec 16, 2008 | 05:30 PM
The Russian's Avatar
sounds very simular to my car! nice!
Old Dec 16, 2008 | 05:34 PM
505max94se's Avatar
thanks
do you have an equal length y-pipe too?
Old Dec 16, 2008 | 05:40 PM
Jeff92se's Avatar
I'm needing a caw
You weld like Greeny. Flux core rig? Nice idea though. Is my whole exhuast now non-existant?
Old Dec 16, 2008 | 05:44 PM
Damn that sounds good.
Old Dec 16, 2008 | 05:46 PM
Greeny's Avatar
¯\(°_o)/¯
Haha!! I thought the same thing when i seen the welds, and predicted your post..
Old Dec 16, 2008 | 05:47 PM
505max94se's Avatar
No I was using gas but for some reason it kept wanting to burn through on the lowest heat setting. I was using a Lincoln Weld-Pak 175HD. Normally, I can weld better than this even with flux. It looks like **** but it doesn't leak.
Actually I was welding a little more like Jeffy
Your exhaust is now on Jon94se's Maxima.
Old Dec 16, 2008 | 05:55 PM
PulsarGTS's Avatar
That sounds......really good!
Old Dec 16, 2008 | 06:00 PM
DanNY's Avatar
Ad·min·is·tra·tor
"my welds starting to look better once i got a grinder"
does adding that bend cause more of an restriction?
Old Dec 16, 2008 | 06:03 PM
505max94se's Avatar
lol, I have a grinder, but I didn't want to sacrifice strength for appearance.
Probably
Old Dec 16, 2008 | 06:06 PM
http://www.youtube.com/watch?v=q0leVqKCLFU
you can hear it till the turbo spools...
Old Dec 16, 2008 | 06:14 PM
CMax03's Avatar
Sounds nice! How does it pull from low RPM to Mid to high?
Old Dec 16, 2008 | 06:19 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Is the equal length Y-pipe originally a WSP Mandrel Bent version that was modified by you?
Old Dec 16, 2008 | 06:21 PM
505max94se's Avatar
Thanks. It pulls pretty good. It seems like it gained power everywhere.
Old Dec 16, 2008 | 06:22 PM
505max94se's Avatar
yep
Old Dec 16, 2008 | 06:23 PM
505max94se's Avatar
sounds good. OS Stillen?
Old Dec 16, 2008 | 06:25 PM
mrkanda's Avatar
So, what is this an upgrade from- just a standard WSP mandrel bent Y-pipe and stock cat and catback to the modified ELYP plus a full WSP 2.5" catback and performance cat? I just wonder what we are comparing from pre-mod to post-mod.
Old Dec 16, 2008 | 06:26 PM
QNO_A32's Avatar
sounds real nice. props to you for having the ***** to hack up your y pipe.
Old Dec 16, 2008 | 06:29 PM
505max94se's Avatar
Before, I had a full WSP exhaust with an unequal length WSP Y-pipe. Now, I have the same exhaust with an equal length Y-pipe.
Old Dec 16, 2008 | 06:33 PM
no i have a custom 2.5 inch piping w warp y pipe and hollow muffler....with a resonator...I had a full 2.5 piping, no cat, and greddy evo2, and it was way too loud and way too raspy....very happy with my setup now..
Old Dec 16, 2008 | 06:56 PM
Matt93SE's Avatar
STFU n00b!
heh.. one of my neighbors in a honduh called me a ricer last week cause of how splatty my WSP Y and rusted out Greedy exhaust sound... it's BAD. I need to redo the whole thing..
burhan92SE's Avatar
sounds awsome dude....how about ur gas milage? any up and downs? my exhaust setup more sounds like a muscle car than tuner lol
and thats a pretty gud weld...just grind the mountains on it and then buffer it...its gonna look shiny and all nice
Old Dec 16, 2008 | 07:10 PM
RA030726's Avatar
I'm nutty for Nissans
Nice job, where did you source that bend?
Old Dec 16, 2008 | 07:55 PM
internetautomar's Avatar
mod or sell?
sounds good at idle, but the rev part doesn't thrill me.
let's see, tomorrow I get the tires put on, then I'll get the exhaust done as long as it's only a pipe. Dam VGs
Old Dec 16, 2008 | 08:09 PM
Dhunterx's Avatar
Sounds fantastic! Any VG guys willing to try the same thing? I'd love to hear how that sounds.
Old Dec 16, 2008 | 08:31 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
as soon as i learn how to weld it's something i'd like to try. tho without equal length headers it won't probably show out its true potential my design will be different tho, and will not have such a tight turnaround there.. rather passing the front bank pipe over the rear bank pipe.. the rear bank pipe will start out going towards the bumper then make a gentler bend and go across to the other side of the front bank pipe (which will move over 3 inches to go into the passenger-side of the junction) and the rear bank pipe will attach to the driver-side of the junction. that way the bends won't be as severe.
Old Dec 16, 2008 | 10:13 PM
505max94se's Avatar
I made it out of about 7 or 8 angle cut sections of 2 inch pipe. I originally made it with a regular mandrel bend, but it hit the ground as soon as I went over a bump.
Old Dec 16, 2008 | 10:18 PM
505max94se's Avatar
I thought about doing it like you are talking about, but I'd lose ground clearance and it would have been more work. I'm planning on making headers for it when I have time.
Old Dec 16, 2008 | 10:20 PM
blacksmax93's Avatar
looks good to me if you ask.
Old Dec 16, 2008 | 10:22 PM
505max94se's Avatar
It's actually alot quieter than it seems in the video and not raspy at all. Sound isn't always the same through a camera than it is in person. It's actually almost as quiet as when I had a 5th gen muffler. The intake is louder than the exhaust...
I should make another video with the camera a little further away because the camera was really close to the exhaust. Maybe I'll make an in-car video too.
Old Dec 16, 2008 | 10:23 PM
505max94se's Avatar
Thanks!
I don't know about gas mileage just yet.
I don't want to grind it, because I don't want to sacrifice any strength and honestly, I don't care what it looks like as long as it doesn't leak or break.
Old Dec 16, 2008 | 10:46 PM
well it won't make you lose ground clearance as long as you make the front-bank pipe OVER the rear-bank pipe. that way the rear-bank pipe, crossing under the other pipe, will be at the same level as the ypipe was originally. i'm trying to make a diagram of it.... i don't have CAD so, as only I can do, i'm making the whole thing in PowerPoint. Yes. I know. It's kinda sad.
Old Dec 16, 2008 | 10:50 PM
505max94se's Avatar
I think I get what you're saying now. Maybe I'll sell my Y-pipe and make one like you're talking about when and if I make headers.
Old Dec 16, 2008 | 11:09 PM
i think the real tricky part is whether to have crossover happen behind the axle, between the axle and oilpan, or in front of the oilpan... i think that all depends on how much pipe you need to equalize the lengths in the first place, and how wide you swing it. i was thinking that angling the rear bank's pipe toward the crossmember and running the pipe as close as possible to the member without hitting it will give you a gentler curve and more flexibility with the design as well. not to mention the shifter support rod and its bracket kindof get in the way of making a REALLY wide sweeping turn... here is a pic of the underbody of my car for reference. the bar at the top of the pic is the passenger side axle. and pardon the mess... i still haven't fixed my tranny leak and apparently my ps pump or hoses are leaking too c'est la vie.
Old Dec 16, 2008 | 11:25 PM
505max94se's Avatar
I thought about alot of different ways to do this, but when you look under the car you quickly realize that there isn't much room to do anything.
FYI, my Y-pipe is very close to being exactly equal length. I used a string to figure out my lengths.
Old Dec 17, 2008 | 02:34 AM
ok well being that i made this in powerpoint... it's about as good as it's gonna get. but the basic idea is the same. just... not so crude.
Old Dec 17, 2008 | 08:54 AM
hadman's Avatar
That has a really nice tone to it.
Old Dec 17, 2008 | 10:12 AM
mod or sell?
you needed a mandrel donut.
some like that.
Old Dec 17, 2008 | 10:21 AM
Jeff92se's Avatar
I'm needing a caw
Hope he likes it. I think he's selling though? Too bad, those flanges cost me a pretty penny.
