front wheel hub
front wheel hub
I need to replace mine and found a 92 maxima(dohc) at the junk yard and was wondering the hub will fit mine (sohc) also what size is the axle bolt (bolt holding driveshaft to hub)
36mm but as stated the actual splined part is larger on the VE axles for whatever reason. So if you wanted to put the LSD VE5 tranny on a VG engine like i did, you have to use the LSD axles, meaning you have to use the VE hubs.
Maxima_Joe
11-25-2015 08:19 AM
BassAddictJ
08-04-2015 11:38 AM
