Want to tighten up my handling...where to start?
Old Feb 11, 2010 | 07:00 PM
wcpierson's Avatar
Im looking to get a more responsive handling out of my maxima on a tight budget. My question is where do you suggest I start, what mods, and what parts/bushings to replace to get the most bang for the buck.
Old Feb 11, 2010 | 07:15 PM
BenStoked's Avatar
Jesus was a Zombie.
where are you starting, stock?
Energy suspension bushings all around (rear parallel links for a 3rd gen, front control arm bushings for a 4th gen (really)). new struts (tokico recommended), eibach springs.
ebay front strut tower brace.
can't remember sway bar options...
Old Feb 11, 2010 | 07:18 PM
wcpierson's Avatar
Yes starting completly stock...car has 139k miles on it and has total prostitute steering(loose)
Old Feb 11, 2010 | 07:22 PM
chrome91's Avatar
ebay front strut tower brace is a good start, 15 bucks plus shipping and i could feel a huge difference on sharp turns, and as said rear sway bar and Eibachs
do you have a GXE? if you do, you can swap springs with a SE, SE springs are stiffer
Old Feb 11, 2010 | 07:26 PM
BenStoked's Avatar
Jesus was a Zombie.
ooh, good call. not as good as eibachs, but better than stock, and cheaper, too..
may consider new ball joints, and tie rod ends, as well as an alignment.
Old Feb 11, 2010 | 08:18 PM
chrome91's Avatar
lmao holy crap 9 guests viewing right now
i might do the SE spring swap next time a SE goes to the junkyard, really with the strut brace sharp turns feel fine but a bit more stiffness would be nice, but i might even keep my GXE's. (never EVER cut your springs though, thats ghetto and the 16 year old with a riced Civic way out). if things significantly change after i go turbo and i need to go a bit lower i'll get Eibachs but really i cant see how things will change
apparently the rear strut bar helps a ton with handling, a guy on here wrecked his 3rd gen and had the rear bar for sale but wouldnt ship up here. otherwise i havent seen many for sale
another thing is for anyone wondering, coilovers wont work for 3rd gens because how theyre designed, you will most likely blow your struts
and with strut braces, really it doesnt matter if you get a $15 ebay one or a $200 or whatever Stillen. same thing as generic brand aspirin and brand name, youre just paying more for a companies logo stamped on it.
Old Feb 12, 2010 | 01:11 AM
maximo018's Avatar
1st off define tight budget? How much can you spend?
Old Feb 12, 2010 | 05:58 AM
wcpierson's Avatar
Im trying not to spend more than $200
Old Feb 12, 2010 | 06:41 AM
gfnk357's Avatar
You'll want to check the bushings on you control arms, if they're bad they can make the car really sloppy. When I replaced my bushings it made a huge difference in handling.
Old Feb 12, 2010 | 06:53 AM
maxitech's Avatar
Bushings make a substantial difference for not a lot of money, IMO...
Old Feb 12, 2010 | 07:33 AM
BenStoked's Avatar
Jesus was a Zombie.
$100 should do all four corners
ebay fstb $25
used SE springs: $50 (?) if bought locally, or junkyard
Old Feb 12, 2010 | 08:21 AM
wcpierson's Avatar
ebay fstb $25
Suggestions on a retailer or a certain set of bushings?
Old Feb 12, 2010 | 09:24 AM
BenStoked's Avatar
Jesus was a Zombie.
courtesy parts ES bushings:
http://www.courtesyparts.com/energy-...ml?cPath=1610&
http://www.courtesyparts.com/energy-...ath=1783_5831&
(^will need modification to fit, see stickies)
ebay fstb: any ebay store with good ratings.
Old Feb 12, 2010 | 11:06 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
nc90gxe recently installed an Addco rear swaybar and said it made 'all the difference in the world' and that he doesn't hardly need to slow down for turns anymore.
Old Feb 12, 2010 | 11:43 AM
wcpierson's Avatar
Any Difference between the SE and GXE FSTB?
Old Feb 12, 2010 | 11:47 AM
depends what year. 89-91, no cuz the SOHC VG was the only engine option. starting in 92 (and through 94), yes, because that's when the SE gained the DOHC engine (aka VE), whose intake manifold is in the back of the engine bay instead of the front, therefore the FSTB has to be able to go up-and-over the intake manifold. I have a bar that will work on a VE i think.
Old Feb 12, 2010 | 12:14 PM
wcpierson's Avatar
I have a GXE so does that mean either strut bar will work on my car since the intake manifold is on the front of the engine?
Old Feb 12, 2010 | 12:18 PM
James92SE's Avatar
2 VE's are better than one!
Correct, since you have a GXE either bar will work
Old Feb 12, 2010 | 12:32 PM
er yea... i should have said "doesn't matter on GXE, but for SE {what i said}"
Old Feb 12, 2010 | 12:50 PM
Maximan190's Avatar
strut bar for VE -
strut bar for VG -
for sway bars, you can get the suspension techniques set also - found on shox.com, ebay, etc
Old Feb 12, 2010 | 01:22 PM
Jeff92se's Avatar
I'm needing a caw
front / rear bushings made a BIG difference in handling. Way more than a strut bar.
Plus you get the chance to play with fire
Old Feb 12, 2010 | 01:28 PM
Old Feb 12, 2010 | 08:36 PM
Niccos89's Avatar
Free option.
Grind out the glue on the caps of the strut towers and around the panels, drill holes, weld it back together.
That epoxy **** stretches pretty badly.
Haven't done this on my Maxima yet, doing it on my other car though, have seen it in action, it almost eliminates the need for braces.
Old Feb 12, 2010 | 08:44 PM
BenStoked's Avatar
Jesus was a Zombie.
I just drilled mine out, like wayne did. probably slower to take them out, but I guarantee I didn't have to wait for it to cool down, again (actually, come to think about it, I just pressed tehm out, they were so shot...).
Old Feb 12, 2010 | 09:15 PM
ve30max's Avatar
I recommend not using the bushing punch loaner tool form Autozone, or anything like it. If you know a shop than can press them in, utilize that connect first, even if it cost a little bit. It's hard to use those punches with precision, hence a sore hand or two, but you may get some guns out of the deal since it takes some serious punching. I never thought to heat them up when I was doing it, but that's the DIY method I would approach now, if I couldn't afford to take em to the man with the hydraulic press.
Old Feb 12, 2010 | 09:32 PM
chrome91's Avatar
I just drilled mine out, like Wayne did. probably slower to take them out, but I guarantee I didn't have to wait for it to cool down, again (actually, come to think about it, I may have just pressed them out, they were so shot...).
7 minute gap double post
Old Feb 13, 2010 | 07:28 AM
BenStoked's Avatar
Jesus was a Zombie.
whoops! fixed, not sure how that happened.
Old Feb 14, 2010 | 02:05 PM
JRS89MAX's Avatar
Like Chrome said a strut bar. Felt a difference when I put mine.
Old Feb 14, 2010 | 06:58 PM
Originally Posted by Niccos89
Free option.
what exactly are you talking about.... what epoxy?
Old Feb 14, 2010 | 07:08 PM
CMax03's Avatar
As far as I'm concerned the bushings would be the least expensive mod.... but the following are absolutely necessary:
1. Wider rims
2. Wider tires
3. Sway Bars F/R (ST) or rear only(Addco) with poly bushing on the front mid section bushing
4. Lowered coil springs
5. Quality struts better dampning than stock.....
6. Lower strut brace (Blehmco)
7. ES bushing upgrade F/R or Spherical bearing parallel links setup (Blehmco)
8. Rear sway bar links (Blehmco)
9. For the extreme... Subframe brace (Warpspeed)
10. FTSB
11.RSTB (Blehmco)
Hope this helps.... but this is an awesome handling car when upgraded!
Old Feb 14, 2010 | 07:19 PM
ve30max's Avatar
Free option.
I am also curious as to what you have described, it doesn't sound too safe....................
Old Feb 15, 2010 | 12:19 AM
maximagician's Avatar
i havent tried that method
but i have drilled em out(tried not to scratch the insides)
last time first i drilled some (to make softer)then used a big clamp and sockets to press them out
even though i lubed them they squeak a little,and i had to go back and add washers on the side that had none because one half of one bushing kinda moved out
Old Feb 15, 2010 | 01:13 AM
Niccos89's Avatar
Look at where the panels join together in the engine bay (the sheets of metal, together...not where it joins chassis or firewall), and look at the hats on the strut towers.
Its epoxy...almost all Nissans of the era are produced this way. Very common mod for imports is to take to that glue with a grinder, and weld it back together..it reduces flex alot. Strut brace will help just as much...and the welding isnt really considered worth the time unless you have to empty the engine bay acessories for other reasons.
Few other places along the chassis and firewall you can weld as well.
Regarding strut braces....has anyone seen one for the 3rd Gen that bolts to the firewall ? I find those alot better than theb races that just go from one strut to the other. I've seen these for imports as well...but not for a 3rd Gen.
Old Feb 19, 2010 | 05:03 PM
Maximan190's Avatar
have any of you poly folks went and drilled and tapped in grease fittings on the factory arms/links?
like here
I know you should grease it up before you press in the new bushings, but with the fittings you could periodically grease it every oil change or so. Since its my daily driver, any squeaks from this car are going to bother me and some point or another Anybody have bushing squeaks to speak of?
Old Feb 19, 2010 | 07:31 PM
BenStoked's Avatar
Jesus was a Zombie.
I've had ES in the back for about two years.
the squeaking is not too bad, unless I get on some Podunk road, then it squeaks continuously. if you figure out how what zerk fitting to use, let me know (constantly in BFE).
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
thenewguyy
Sep 12, 2015 11:12 AM
ag90fox
Sep 9, 2015 12:22 PM
trungg86
Sep 4, 2015 04:58 AM
