key problems
Old Dec 18, 2001 | 10:36 AM
spyhunter's Avatar
key problems
hey guys, i just had a new nissan factory key cut from and older working copy of it. the new key doesn't work but look identical when compared. whats going on? and stupid me lost the receipt from the place that cut the key...grrr....
Alex
Old Dec 18, 2001 | 12:12 PM
Sudesh's Avatar
it's a copy of the damn key man..what do you expect? They always work but takes some time to break in. Gently wiggle it around until you get it to work..it will.
Old Dec 18, 2001 | 12:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: key problems
Alex
consider bringing it back to the guy who cut the key...perhaps he's a lock smith or a person who actually knows a lot more about locks and keys?
Old Dec 18, 2001 | 01:32 PM
Bman's Avatar
Maybe if the old key is all rounded off and worn, the locks have gotten used to this? Maybe try taking it back and get them to round the edges off a bit more with that wire wheel you see on the cutting machine. It probably beats trying to replace it.
Old Dec 18, 2001 | 02:21 PM
spyhunter's Avatar
thanks to all for the input, i kept playing with it today and i can at least turn it to unlocks the doors and trunk with effort and i can turn the key to iginition but no further, i'll keep at it.
Old Dec 18, 2001 | 02:45 PM
max91se's Avatar
Does anyone know if you can get an original factory key from a nissan dealership?
Old Dec 18, 2001 | 03:00 PM
spyhunter's Avatar
i got mine off ebay but i'm sure you can get one at the dealership
Old Dec 18, 2001 | 03:31 PM
JD's Avatar
JD
Keys
Bring the VIN number into a dealership, they should be able to cut it from that. They did for me, however it doesn't work in my trunk...
Old Dec 19, 2001 | 12:54 AM
Mikes90GXE
As a key gets older, it gets worn down and tends to work less reliably. A copy of the worn key may not work at all (as you found out). This problem occurs a lot with Max's.
There is usually a key code in the glove compartment that the dealer can cut a new key from. They usually work OK.
Old Dec 19, 2001 | 05:23 AM
spyhunter's Avatar
well when i bought the car it came with like 4 keys, the one that wasn't the most worn down, which visually looks new, was the one that i used to copy. it worked perfectly where as the copy did not. pretty strange if you ask me
Old Dec 19, 2001 | 10:11 AM
Mr. Nismo's Avatar
Yup, they cost about $5 each and make sure they say Nissan on them! Sometimes they'll try to sell you a cheapy without the black plastic end.
DJLAX152
May 4, 2021 11:46 AM
maxinout93
Oct 16, 2015 02:53 AM
ajahearn
Sep 19, 2015 03:03 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
intimidator
Sep 5, 2015 07:23 PM
