How do I Know its time to replace my struts?
Old May 26, 2011 | 03:10 PM
wcpierson's Avatar
How do I know when its time to replace my struts? Is there any testing for this or is based on mileage?
Old May 26, 2011 | 07:29 PM
chrome91's Avatar
check for any weird noises, and firmly press down all of your weight on the front and rear of the car (not at the same time, one at a time). if the whole rear or front bounces up and down more than once or twice, you probably need new struts. with good struts, you should be able to press down and let go and the car should bounce up/down once or twice
Old May 26, 2011 | 11:10 PM
coolsun's Avatar
something helpful here
http://www.youtube.com/watch?v=80C2N9ecSj4
Old May 28, 2011 | 05:00 PM
Brad92SE's Avatar
I had a situation where my rear end would shimmy when going over small bumps at highway speed, but never got any repeated bouncing. I finally found one rear strut was completely gone when I parted the car out, as in the shaft was completely loose in the housing
Old May 28, 2011 | 05:37 PM
Mr. Brett's Avatar
Good struts will rebound 1.5 to 2 times.
Anything over that means the struts are shot. Get the car bouncing up and down, once at each corner, and count how many times the corner rebounds once you stop.
Another good indicator of bad struts (or struts on their way out) is if they "hiss" when you go over speedbumps or the likes.
Old May 28, 2011 | 08:19 PM
chrome91's Avatar
lol this ad popped up when i viewed this thread again
Old May 29, 2011 | 12:52 AM
CMax03's Avatar
When you can push your car's suspension down (by hand) rather easy and get a dance rythm going!
Old May 30, 2011 | 09:43 PM
maxima801's Avatar
^^^^THIS!!!
Old Jun 1, 2011 | 05:02 PM
maxinout93's Avatar
u can sometimes tell by how low the car sits. When I had good struts, my car sat even. When they went bad, the rear sat really low like near the top of the tire, and it bounces around alot.
Old Sep 17, 2011 | 02:01 PM
Grimmrezx's Avatar
bounce the fron of the car itll rock for a longer time then normal if there bad
Old Sep 20, 2011 | 04:14 AM
maximagician's Avatar
Originally Posted by wcpierson
How do I know when its time to replace my struts? \
when you have hundreds of dollars to spend on a 1500 car for the sake of "ride quality"
not tryin to be a d___ ....im just sayin.
kingw323
20
Oct 21, 2015 08:36 AM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
