Question: How to install non-OEM fogs/driving?
Old Jun 27, 2011 | 12:58 PM
Laevateinn's Avatar
What low price fog/driving light can I buy (prefereably low profile, rectangular and clear glass lens) to replace the OEM? And how will I install it without rerouting a new wire and switch? I want to keep the original fogs switch.
Old Jun 27, 2011 | 01:06 PM
torqueymonster's Avatar
Ditto!! Including exterior houing, looks like 7"x3.75" unit ought to do the trick...
Old Jun 27, 2011 | 03:56 PM
BenStoked's Avatar
Jesus was a Zombie.
took me an hour to install mine.
most of that was drilling the holes for the non-self-tapping screws the kit included.
switch is easy. find the two pins that have continuity when the switch is "on".
make sure to use a relay, else you can fry the switch, and stink up the car (done it before on other projects...)
Old Jun 27, 2011 | 10:42 PM
Laevateinn's Avatar
How will I exactly do that?
Old Jun 27, 2011 | 10:57 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
if you have to ask that after the answer he already gave you, then this task is too difficult for you, period. have a shop put them on.
Old Jun 27, 2011 | 11:52 PM
Laevateinn's Avatar
I'm quite sure there is a difference between an answer and a detailed instruction. Since he got his's working, I'd rather ask for specifics, if he doesn't mind, to avoid errors as much as possible.
@BenStoked: Do you have a picture of your fogs?
Old Jun 28, 2011 | 05:58 AM
BenStoked's Avatar
Jesus was a Zombie.
not anymore.
I had a set of these.
http://www.google.com/products/catal...=0CGkQ8wIwBDgK
Old Jun 28, 2011 | 06:12 PM
it's gonna be the same for all cars not just maximas...
you need a power source, a fuse, a relay, and a switch.
control circuit: power source (inside car such as cig lighter wire) -> switch -> relay "coil" -> ground
light circuit: power source (unfused location off battery post) -> fuse -> relay "throw" -> lights -> ground
Old Jun 28, 2011 | 09:05 PM
maxinout93's Avatar
My kit didnt come with all that. I got mine from walmart, If you look at my signature pic you can see how mine look
Old Jun 28, 2011 | 11:45 PM
Laevateinn's Avatar
I'm kinda having an idea of it. Since I got the battery and fogs switch, I just need a new fuse and relay, right? Is it necessary to have a fuse and a relay for each light or just one for both? So can I just cut the original fogs socket or reroute a new wire from the switch itself?
Old Jun 28, 2011 | 11:47 PM
Laevateinn's Avatar
Do you mind posting a front view of your max and your wiring set up? If you can take a picture with both of your headlamps and fogs on, that will be awesome.
Old Jun 30, 2011 | 07:31 AM
one for both is fine, as long as the fuse is rated for enough amps to handle roughly 2x the amperage of both bulbs combined. A=W/V
the stock switch is fine to reuse if you have one.. it may even be wired into the fuseblock already if your car was prewired for fogs (and just missing the relay). Some 3rd gens without fogs already had the wiring behind the dash and only needed to add a stock style blue or green relay into the stock relay socket.. others did not come with the wiring.
Old Jun 30, 2011 | 01:29 PM
Mine is wired, but I need to yank the nasty old lamps that aren't working and replace them... probably just pull out the connectors and put in new ones, throw on new lights and whammo!
Old Jun 30, 2011 | 10:41 PM
Laevateinn's Avatar
It's an SE so it has two fogs that I just removed.
Old Jul 1, 2011 | 01:54 AM
Hectic's Avatar
The circuitry is all there, buy fogs and mount them. Connect 2 wires on each side, job is finished. OEM switch and all.
Old Jul 1, 2011 | 07:34 AM
wait... so if the fogs that were on there worked... then all you have to do is attach the wires from the new fogs, to the wires from the old fogs, and you're done.
Old Jul 1, 2011 | 10:51 AM
chrome91's Avatar
i had these, just tapped them into the headlights so they came on when the headlights did
Old Jul 1, 2011 | 06:27 PM
[IMG]http://oi52.tinypic.com/30cvedw.jpg[/IfMG]
yea but on an SE it's even easier than that, all he has to do is wire them into the same wires that the stock ones came off of.
Old Jul 1, 2011 | 06:57 PM
chrome91's Avatar
most GXE had foglight wiring tucked in though, some didnt but most did
im pretty sure mine had the wiring harness tucked and i didnt know
Old Jul 2, 2011 | 07:40 AM
my USDM Fed-spec non-Bose 90 GXE did not. But some US-spec GXE's did have wiring, and even rarer, some actually had fogs (2/3 height of the SE fogs). I'm not sure if it's a year thing, or a Bose-or-not thing, or what, that decides which ones got it and which didn't.
Old Jul 2, 2011 | 09:45 AM
shiloh51933's Avatar
My GXE has the wiring and I got an OEM switch to put in the blank spot were the oem fog switch goes. It looks nicer then an ugly after market switch and I like the fogs to work like factory with parking lights/head lights. I did install an after market led style fog light set and wired the hareness separated from oem wiring but wired into fuse block under dash. I can use them without the parking lights/head lamps illuminated. Personally I'd keep the OEM wiring/OEM switch for whatever foggies your hooking up. I'm feeling the Stillen front lip with some Hyper White bulbs in rectangular fog lenses. Eventually I'm going to mod some clear lenses with mini projector fitted into them. This will happen after my Max Stillen ground effect kit is installed and the whole car is wearing fresh paint.
Old Jul 8, 2011 | 11:35 PM
Laevateinn's Avatar
The OEM fogs arent working and destroyed that's why I want to change them. So I'll just cut the connector out, and wire the lights?
Old Jul 10, 2011 | 09:26 PM
maxinout93's Avatar
This is how mine look!
Last edited by maxinout93; Jul 13, 2011 at 05:52 AM. Reason: gotta move them over a bit because they the pass side one isnt aiming right
Old Jul 11, 2011 | 08:13 AM
that or put spade connectors on the end of the new lights' wiring so you can just push them into the original plug (assuming it was that kind of plug... i never actually saw what one looked like)
Old Jul 12, 2011 | 06:12 AM
CMax03's Avatar
Old Dec 7, 2011 | 06:03 PM
Laevateinn's Avatar
I haven't installed any fogs yet but according to the pics, it's installed by the metal thing under the bumper. I want to install my Pilot NV-100Z where the stock fogs were installed. How will I do this? Do I have to drop the bumper?
Old Dec 8, 2011 | 07:34 AM
doubleclutch92's Avatar
All I did was cut the stock wire and plug from oem lights. Bought some walmart lights and put the connector on the aftermarket lamps. Installed the mounting hardware and lamps. Plugged the new lights on to the oem connectors and aimed them on the wall.
Old Dec 8, 2011 | 08:49 AM
Laevateinn's Avatar
Did you use self tapping screws?
Old Dec 8, 2011 | 09:50 AM
Yes, drove them in with a screw driver. Lens is cracked pretty bad now on both sides and one is out. Need to replace them with something new.
Old Dec 9, 2011 | 06:52 AM
CMax03's Avatar
Lamin-X the next ones and you'll be ok!
Old Dec 9, 2011 | 07:39 AM
Cool, I'll have to look around for some of that for the next set of light I get.
Old Dec 9, 2011 | 02:45 PM
Laevateinn's Avatar
Do you remember what's the size of the self tap screw that you used?
Old Dec 9, 2011 | 03:00 PM
I cannot recall, its been so long. Just use the hardware that came with the kit.
Old Dec 11, 2011 | 05:04 PM
prappl's Avatar
I had a set of those blue glass ones and they did alright. I now have some that are a pretty close match to stock. $20 at Harbor Freight, sku 37350 "super pick-up lamp" comes in yellow/clear with or without metal guard, and it fits on the inside of the stock brackets.
Old Dec 12, 2011 | 10:00 PM
Laevateinn's Avatar
What do you mean it fits? without drilling? how did you secure the single bolt?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
