What did I do wrong?
Old 12-27-2011, 01:59 AM
TonyJr's Avatar
Like a dumd *** I cut the factory wire harness on the radio in order too install my aftermarket radio it works some what but with problems. The problems are my dimmer for the gauges don't work , the radio doesn't keep memory, and the factory alarm does work anymore. I went to a junk yard and cut a Bose harness off and splice it back together. Then I bought a walmart a harness kit for my car but it still has all the problem. Does any of these problem have to do with me cutting the harness?
TonyJr is offline
Old 12-27-2011, 05:18 PM
Jesus was a Zombie.
BenStoked's Avatar
blown fuses. bet the running lights don't work, either...
BenStoked is offline
Old 12-27-2011, 06:49 PM
inhalation2's Avatar
Radio
Dude should have bought a radio wire harnest for you car that what I did mine works great
inhalation2 is offline
Old 12-28-2011, 08:26 AM
TonyJr's Avatar
I know but I got lazy. I'm going to try to rewire it back the way it came but I have to find a the same model in a junk yard
TonyJr is offline
Old 12-31-2011, 09:21 PM
CMax03's Avatar
What you did wrong is messed with your car having no knowledge of it!
CMax03 is offline
Old 01-01-2012, 07:20 AM
Hectic's Avatar
If your dimmer doesn't work, you either miswired the illumination wire so that the entire circuit is now at full voltage. Find the red and yellow wire and snip it where you spliced, see what happens.
My guess is you swapped illumination and constant wires when installing the replacement connector. It would explain both why the HU doesn't retain memory and why the dimmer doesn't work. Especially if you live in Canada and have DRL. Otherwise, the HU would only turn on with the lights.
Hectic is offline
Old 01-01-2012, 11:02 AM
shiloh51933's Avatar
+1
shiloh51933 is offline
Old 01-01-2012, 03:14 PM
arsonist63086's Avatar
blown fuse
arsonist63086 is offline
Old 01-02-2012, 04:26 AM
TonyJr's Avatar
Sound right about the illum. Wire I'm going to check it out today n see what's up
TonyJr is offline
Old 01-02-2012, 06:55 AM
STFU n00b!
Matt93SE's Avatar
What Hectic said. it's a common problem for people that cut into their harnesses. The lazy way out is to buy an adapter harness for $10 that you just plug into the factory harness. makes a radio swap take 15 minutes.
Matt93SE is offline
Old 01-03-2012, 07:36 AM
TonyJr's Avatar
Other problem I'm having also is when the key is out and I open the door the seat belt doesn't move forward for an easy exit out the car. I would have to put the key to the on position in order for the seat belt to move forward.
TonyJr is offline
Old 01-03-2012, 09:33 AM
STFU n00b!
Matt93SE's Avatar
either a blown fuse or a blown fusible link.
Matt93SE is offline
Old 01-03-2012, 07:39 PM
TonyJr's Avatar
What do u mean by fusible link
TonyJr is offline
Old 01-03-2012, 08:33 PM
cant be a fusable link since the only fuseable links are in the engine bay and fuses only the alternator and most of the electrical in the car so if one goes out the most of the stuff wont work...
Old 01-04-2012, 11:10 AM
TonyJr's Avatar
I'm going to check every fuse in that the car has.
TonyJr is offline
Forge277
06-13-2016 09:26 PM
BobTX10
10-07-2015 08:43 AM
bigfrank
10-01-2015 12:51 PM
pears
09-18-2015 05:25 AM
Quick Reply: What did I do wrong?
