cranking problem
if its a automatic, check your shifter bushing. i had the same thing, wouldnt do anything when i turned the key but if i rocked the car back and forth it would start. shifter bushing prevented it from going into park all the way
if not it sounds like your starter has a bad spot on it
the starter is just a few years old. I'll check the connections tomorrow and the shifter bushing. i hope it's not starter cuz it's like $120.
thanks for the reply guys .
off topic cause i dont wanna make a new thead but im smelling gas when i first turn the car on. i smelled around the engine bay and dont smell any gas. any idea where it could be coming from. anyone had this issue before ?
change all the rubber fuel lines under the hood (5/16)
shifter bushing is worth a try and its a $3 part from Nissan, just gotta remove the heatshield under the car to replace it
It sounds like a loose fusible link connection (@ poitive battery post) maybe the wire connections are a bit loose fitting.....Also these starters on the 3G seem to be problematic especially after sitting for a while.....
Im blaming the ignition/key assembly, or anywhere between that and the starter wire. (at least for my case) Sometimes mine takes a few trys to start, but sometimes it starts on the first shot. When it doesnt start, i hear the *click* every time i turn the key, so if after a few trys and it still doesnt start, i keep a jumper wire in the door pocket and just pop the hood and hook it to the starter wire and touch the other end to the + batt terminal, and this always starts it. This problem still persists even after i put in a new starter
will do and thanks for the size i never knew what it was and how many feet of line do i need?
that would cause it to smell inside?
and
thanks ill check it out and replace before it gets bad.
i got a starter from pull a part and also got some ngk spark plug wires
from the same car and now the car starts on the first try.
i was thinking it could of been the was wearing out but thank god i made copies years ago as spares jus incase it does wear out.
thanks for the input guys, i got the car to start now on the first try by changing the starter and the spark plug wires. ill still change the shifter bushing cuz its prolly the oem and ill be changing all the rubber fuel lines.
and
