Driver door off alignment.
Old Sep 30, 2019 | 03:26 PM
tmorales509's Avatar
Maybe just from the years of opening and closing but my driver door is probably about a 1/2" lower so i have to pick it up a little to close it easily otherwise it kinda gets stuck on the metal hinge thing. How do i go about adjusting the door or is there something i have to change?
Old Sep 30, 2019 | 06:56 PM
DanNY's Avatar
Ad·min·is·tra·tor
pick up new(er) hinges and it should solve your issue. looks like lower hinge is missing a bushing.
Old Oct 1, 2019 | 10:50 AM
Thanks, Do you know where i can order them? I looked on ebay and rockauto and don't see any. If not i might try to get some off a junk car but i rather have new ones.
Old Oct 1, 2019 | 05:35 PM
3rdmaxse0's Avatar
I picked up a set last year from tascaparts.com. took some time to get though.
Old Oct 6, 2019 | 06:41 AM
Hectic's Avatar
You don't need new hinges, all you have to do is loosen the hinges, separate them from the body and and re-tighten them while holding the door in place. It's a possible one man job, but easier with two people. It's true the cause of the sagging is wear, but unless you plan on your car being upside down, readjusting them will solve the problem indefinitely, you will have to remove the fender.
Old Oct 6, 2019 | 07:32 AM
RA030726's Avatar
I'm nutty for Nissans
I shim the door at the bottom hinge on every Nissan I work on. Works every time and costs nothing.
Old Oct 6, 2019 | 07:07 PM
ac max 92's Avatar
Shim with washers or pick up new hinges. Swapping the hinges is a 2 man job.
Old Oct 8, 2019 | 05:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
so the fact there's a missing bushing here due to wear and tear doesn't require a new/used hinge? it's not even with the hole...that's ok? some shims will fix that?
Old Nov 15, 2019 | 06:02 AM
Hectic's Avatar
Did not notice that, I keep my graphics driver brightness at the lowest setting, and can't see that unless I raise it to the default 0. In most cases, what I suggested corrects the issue.
Old May 17, 2020 | 07:43 AM
Is there any way i can just cut that old pin out and replace that with new bushing instead of having to replace the whole hinge?
mistur_sleepyass
Aug 30, 2009 08:53 PM
maximabiz
Mar 8, 2008 08:39 PM
tucker
21
Dec 15, 2007 11:21 AM
johnson
Jun 29, 2005 09:20 PM
