nitrous?
Old May 21, 2002 | 09:01 PM
93_SE_boy16's Avatar
nitrous?
does anybody have a VE and is running nitrous on it? if so what is the best kit to get?
Old May 21, 2002 | 09:10 PM
Michael's Avatar
Back in a 3rd Gen.
Re: nitrous?
You gotta pronounce it right its NAAAAWWWWSSSS.
sorry thats not constructive...but I had to do it.
Old May 21, 2002 | 09:14 PM
Maximan190's Avatar
Re: Re: nitrous?
Old May 21, 2002 | 09:19 PM
Michael's Avatar
Back in a 3rd Gen.
Re: Re: Re: nitrous?
Originally posted by Maximan190
Old May 21, 2002 | 10:04 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
EFI kit #05124 for the 3.0L
Plenty of other info is in the archives-->
http://forums.maxima.org/search.php
Old May 22, 2002 | 10:57 AM
nismo1989's Avatar
Re: nitrous?
I just put in the ZEX kit, but I have a VG. It was so easy to set up, and the fittings and such are a lot less complicated than NOS or JGE. I have 3 types of jets for 55, 65, &75hp too.
Old May 22, 2002 | 11:04 AM
DA-MAX's Avatar
Re: Re: nitrous?
how are you dealing with the TPS voltgae issues???
Old May 22, 2002 | 11:11 AM
nismo1989's Avatar
voltage issues??? Please elaborate, I was unaware there were issues. I have used it like twice, it's only been hooked up for a few days now. What throttle position switch issues are there? Thanks.
Old May 22, 2002 | 11:19 AM
DA-MAX's Avatar
Re: Re: Re: Re: nitrous?
did you connect the control/solenoid box to the TPS?? I know the 4th gen guys were having a problem since the Zex uses a specific TPS to activate the solenoids and the 4th gens TPS voltage was higher then what was required! maybe the 3rd gens are different.
Old May 22, 2002 | 11:40 AM
pearl93max's Avatar
how many miles on your max nismo??? I want to get nawz, but i think I have too many miles...160k. But the engine is very stonmg and has n mechanical problems. If i did get a kit, i wouldn't run more than 50 shot newayz.
Old May 22, 2002 | 11:57 AM
DA-MAX's Avatar
mialage doesn't really matter per sae(sp?)....as long as compression is optimal its all good! I'd be more worried about your tranny then the the motor!
Old May 22, 2002 | 12:07 PM
nismo1989's Avatar
no worries about my tranny, that's for sure (could use a new mount, though). Oh, and I have about 186K on the odometer but runnin real strong...
Old May 22, 2002 | 12:45 PM
blackandwhite's Avatar
To them I'm like an idol
Re: Re: nitrous?
Really?
Wet or dry? Do you have a write up, or can you post some quick instructions? Where's the switch? Where's the bottle? And how much was the kit?
Sorry for all those...just curious.
Old May 22, 2002 | 12:50 PM
nismo1989's Avatar
Originally posted by blackandwhite
Really?
$500 for the kit. I'll get some pics and update my page soon, don't worry. The selenoids and everything is all kept in this nice and neat box that bolts up to the firewall. The switch can be positioned to activate the system at pretty much whatever throttle position you want I think, but mine is set to activate when armed at about WOT. I plan on posting a link to my page when I get it updated with some good pics so look for it...
Old May 22, 2002 | 02:14 PM
Coolice19's Avatar
Hey Nismo Have you ran at the track yet with the Nitrous on your car? I would like to know what a vg could get with some mods and a 50 shot of Nitrous or a 75 shot.
Old May 22, 2002 | 02:23 PM
DA-MAX's Avatar
well maybe it works then...as far as I know the Zex kit has to be tapped into the TPS. not sure but I know the 4th gens were having probs because their TPS wasn't registering the 4 volts(or higher )needed to activate the solenoids at WOT. maybe the 3rd gens exceed 4 volts though
Old May 22, 2002 | 02:30 PM
jim90gxe's Avatar
Re: Re: Re: Re: Re: nitrous?
at 90 degrees (throttle angle) voltage is almost 5v.
Old May 22, 2002 | 02:38 PM
DA-MAX's Avatar
Re: Re: Re: Re: Re: Re: nitrous?
makes a lot of sense then! that does seem like a more easy an effeicent means of activation opposed to the usual WOT pedal switch the other companies use. I still think the traditional window switches are more accurate means though!(past argument I had)
Old May 23, 2002 | 05:28 AM
nismo1989's Avatar
Re: Re: Re: Re: Re: Re: Re: nitrous?
On the new kits there is a sensor that is supposed to learn the voltage curve from the TPS. Maybe they had older kits that didn't have that capability.
Old May 23, 2002 | 05:30 AM
nismo1989's Avatar
No, but as soon as the race (Indy 500) is over I'll be taking it out. I plan on living at the track all of July and doing as much fine tuning as I can now that my old lady is leaving...
I'll definitly have to post some timeslips...
If anyone in Indy wants to see me I'll be at the IRP!!
Old May 23, 2002 | 12:52 PM
Bryan H's Avatar
do a 200 shot, you'll love it!
Old May 23, 2002 | 02:44 PM
pearl93max's Avatar
What should the compression be to run nitrous safly??? And what are some signs of good/failing tranny? My auto doesn't slip at all, but shifts real hard. It jerks you when it shift, mainly from 1st to 2nd. Is this good?
Old May 23, 2002 | 02:58 PM
KLoWnPR109's Avatar
I've been thinking about nitrous too, either that or a turbo but probably nitrous as I can get it installed here in town. If I do though, the first thing I'll be doing is a five speed swap.
Old May 23, 2002 | 02:59 PM
DA-MAX's Avatar
jerking isn't a good sign at all, it might not be the tranny, but it might only be a motor mount especially since it occurs during the 1-2 shift. your tranny might not be bad now, but without a VB mod it definently won't last very long even on a 50 shot. compression for the VG ranges from about 128-170+/- PSI per cylinder...so you have to determine whether or not the readings you get are in an optimal range for the added cylinder pressure the nitrous creates.
Old May 24, 2002 | 08:18 AM
nismo1989's Avatar
You should keep stock compression. Most kits you will buy are made to be used with a virtually stock engine.
Old May 24, 2002 | 08:35 AM
DA-MAX's Avatar
what are you talking about??? I telling him to check his compression not change it.....
Old May 24, 2002 | 08:52 AM
nismo1989's Avatar
Yeah, I don't dissagree at all. I was just elaborating on why the compression should not be changed.
Old May 24, 2002 | 08:58 AM
jim90gxe's Avatar
He's talking about cylinder compression.. not compression ratio. (ie checking for worn rings..)
Old May 24, 2002 | 12:11 PM
pearl93max's Avatar
thanks guys....I got a friend to ride with me and he said it's not sliping at all or showing signs of going out. I'll get his dad to check the compression too. And if all goes well, nitrous will be installed!!!
Old May 24, 2002 | 01:20 PM
DA-MAX's Avatar
good luck....I'd seriously look into the VB mod from either Don or Level 10....just my $.02
Old May 24, 2002 | 03:15 PM
abe805's Avatar
hahahahah
Old May 24, 2002 | 05:06 PM
pearl93max's Avatar
On there web site.....it was just shy of 700 bucks. Is that what you're talking about???
Old May 24, 2002 | 07:39 PM
DA-MAX's Avatar
yeah thats it.....might be $700 but it'll save your tranny in the long run!
Old May 24, 2002 | 09:35 PM
PATRICK94SE's Avatar
Originally posted by abe805
hahahahah
You again?
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
