Got my DET running in my max and have a ?
Old Jul 29, 2002 | 03:26 AM
  #41
carnal_c30's Avatar
Former Sponsor
Originally posted by MAXXspeed18
How much did it cost you all together? seems like putting a RWD engine into a FWD would be alot of $$$$$$....how much was it all together with changing the internales and everthing? I would love to see what that car runs at the track since the other turbo max out there never runs his car
he kept the stock block and put DETs replacements wherever he could he said that before
the other turbomax- Nigel runs, Turbo95Max hasnt doesnt really need to haah butt dyno tells us very much about his car
Old Jul 29, 2002 | 03:18 PM
  #42
ivelweyz
Keeping the thread fresh!!!
Old Jul 29, 2002 | 03:19 PM
  #43
krmaxima's Avatar
PICTURES
and how many horses?
Old Jul 29, 2002 | 03:23 PM
  #44
ivelweyz
Originally posted by krmaxima
PICTURES
I think he said he's getting it DYnoed on the 10th so hold on. Pictures of what? He swapped some internals you probably can't see much difference...
Old Jul 29, 2002 | 03:39 PM
  #45
Canuck's Avatar
Maybe pictures of how the VQ30DET manifold and Turbo fit into our engine bay?
Old Jul 31, 2002 | 10:53 PM
  #46
TILLEYS99's Avatar
Lives in a 11sec maxima
more to come soon.
Old Jul 31, 2002 | 11:15 PM
  #47
97GLE's Avatar
Red X for me
Old Jul 31, 2002 | 11:37 PM
  #48
TILLEYS99's Avatar
http://pstr-m03.ygpweb.aol.com/data2...FWPcwD0180.jpg
Old Jul 31, 2002 | 11:57 PM
  #49
turbo97SE's Avatar
Your set up looks similar to mine. . Me wanna built engine too! You're running boost already? Oooh! I'd run a while without it first to break it in and stay away from temptation. Then you can run like 16-20 psi! Did you lose much bottom end? Did you do anything to the heads?
congrats ... and welcome to the world of turbos!
Old Aug 1, 2002 | 05:43 AM
  #50
KMax2988's Avatar
Originally posted by TILLEYS99
Im using Internals, heads and intake manifold.
The VQ30DET is out of a Y33 Cima (JDM Q45) and good luck finding one they arent too common.
If you don't mind me asking, how did you mount the turbo up? By this post is doesn't look like you used the stock turbo manifolds so I was just curious.
Old Aug 1, 2002 | 05:57 AM
  #51
SleeperSE's Avatar
- Besides the lower CR pistons, what else did you change on the car?
Manifolds? Heads? Rods?
- Is there any place that can get us 9.0:1 pistons? I know that a lot of companies can make custom pistons to your specs, but does anyone know of an actual off-the-shelf piston set?
- Who knows, maybe after a gazillion miles (when mine finally bites the dust), I'll build the motor and go boost-happy.
Old Aug 1, 2002 | 07:49 AM
  #52
turbo97SE's Avatar
Arias or JE??. They're as close to off-the-shelf as you can get
Old Aug 1, 2002 | 10:13 AM
  #53
TILLEYS99's Avatar
Old Aug 1, 2002 | 10:17 AM
  #54
TILLEYS99's Avatar
Old Aug 1, 2002 | 11:56 AM
  #55
JustMaxin96's Avatar
Wow!! Thats gorgeous!! So you put the VQ30DET head on your VQ30DE block and everything else? Can your mechanic do that for me? Congradulations once more.
Old Aug 1, 2002 | 12:10 PM
  #56
breaux124's Avatar
Looking Sweet. When's the next PA meet?
Are you driving it now, or still working some things out?
Old Aug 1, 2002 | 09:43 PM
  #57
i30krab's Avatar
Re: Got my DET running in my max and have a ?
How much vacum do most of you see at Idle mines around 10, Im curious cause my brakes seem really weak. also I should be hitting the dyno on the 10th of august at the nissan meet in PA so I will keep everyone posted.
I will have pics soon.
Very nice work!! When I got the pistons, rings, and valve springs from the VQ30DET, performance cams from the VQ35DE and I shotpeaned the stock rods, I also asked Clark about using the crank and heads from the VQ30DET. He said they are so similar that it wasn't worth the money to fool with them. Instead I balanced and blueprinted the reciprocating mass and CC'd the heads.. I also used the OEM intake manifoldscwhich were extrude honed and gasket matched and the exhaust manifolds which were gasket matched and ported and polished.
It would be interesting to see how the performance of our 2 engines compare non-aspirated. They probably are very close in performance.
Old Aug 2, 2002 | 06:48 AM
  #58
Supa Lao's Avatar
Rob did all the work himself. He's been working on that project for a while now.
Hey Rob, did you paint your front bumper yourself, or did you take it to a place?
Old Aug 3, 2002 | 07:16 AM
  #59
TILLEYS99's Avatar
I did it myself at my shop. I now have a full car spray booth at my disposal.
Old Aug 3, 2002 | 07:40 AM
  #60
Sprint's Avatar
Looks very nice Rob
Old Aug 4, 2002 | 12:47 AM
  #61
TILLEYS99's Avatar
I hit 11 psi today and it feels great. 1 week till I hit the dyno!
Old Aug 4, 2002 | 04:09 AM
  #62
redmaxpa007's Avatar
i SeE what you did therE
thanks for the "test run" last night.. hehe
can't wait till it is tuned..
Old Aug 4, 2002 | 07:28 AM
  #63
NickStam's Avatar
gross
Old Aug 4, 2002 | 07:29 AM
  #64
Originally posted by NickStam
gross
sicko
Old Aug 4, 2002 | 08:22 AM
  #65
Ants97SE's Avatar
Very nice, I'm looking forward to seeing those dynos.
Old Aug 4, 2002 | 07:58 PM
  #66
XXXL Cracker's Avatar
Tilley, thankls for the ride today
Four of us piled into the car and it still took off like a bat out of hell with 800 lbs of people in there. i did not know what to expect.
The car pulls like it normally would, sounds pretty normal and then all of a sudden the boost builds and away you go.
Engine looked great and the car sounded awesome. It was worth the one hour plus ride to get there and the twenty minute detour.
BTW the cars that were in that accident were both mangled. Coming home they had another road down my way detoured for another accident.
NICE RIDE = SWEET BOOST
DL
Old Aug 12, 2002 | 09:52 PM
  #67
MaxSpeedSE's Avatar
TILLEY Why dident you just put the internals from the DET motor into yours, and just buy Negils turbo kit?
-Chri§
Old Aug 13, 2002 | 12:52 AM
  #68
EZEMaxima's Avatar
tilley, are the intake manifold from the VQ30DET a bolt on to our VQ30DE , any hood clearance problem with the intake manifold?
Old Aug 13, 2002 | 06:05 AM
  #69
breaux124's Avatar
-Chri§
I'm pretty sure he bought the motor and everything else even before the turbo kit was available.
Old Aug 13, 2002 | 05:18 PM
  #70
You are correct breaux......
Old Aug 16, 2002 | 08:39 PM
  #71
voltman's Avatar
BTT
Just for the heck of it
Old Aug 16, 2002 | 09:08 PM
  #72
TURBONIUSMAXIM0's Avatar
few ?'s
if i as to take a vq30de block and replace build with all the vq30det is there any thing i should take into consideration or that may cause problems..
is there any sort of MAP of MAF bypass required (i had to on my teg)
nice setup i hope to be following your lead very soon
Old Aug 26, 2002 | 08:27 PM
  #73
avalon42's Avatar
I'd still go with a built engine.
Tilley99, where can we get the VQ30DET motor again, and for how much?
-A
00MAXI
Sep 2, 2015 10:23 AM
paulpearl
Sep 2, 2015 07:50 AM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
25
Aug 28, 2015 10:15 AM
jholley
Aug 11, 2015 09:38 AM
