HELP ! McCulloch Xenon HID kit installation
Old Nov 20, 2002 | 11:47 AM
YUTAKARNB's Avatar
Hi!
I have a problem with my HID kit. The Mcculloch connector that is going to conect to my factory connector has only 2 wire : BLack and white. But the factory connector has 3 wires: Left lamp has Black/ Blue with blue strip/ Green , Right lamp has Black/ Green with yellow strip/ yellow.
How can I do the installation.........
Old Nov 20, 2002 | 12:48 PM
njmaxseltd's Avatar
Your new HID's have no high beams. You only need 1)Power and 2)Ground.
Your 9004 socket has 3 leads. 1)Low beam power 2) High beam power and 3)Ground.
I can't remember which is which, but you only need the low beam power and ground for you new HID's.
Looking at the socket, I'm pretty sure the middle is ground. You can play around from there to see which one will have power when your lights are on.
Old Nov 20, 2002 | 12:54 PM
D1NOnly34's Avatar
Re: HELP ! McCulloch Xenon HID kit installation
Originally posted by YUTAKARNB
Hi!
I have the McCulloch kit in my car, its true you only need two wires, ground and power since u have no more high beams. Dont be worried if you have the wires backwards, cause if you do, when you turn on your lights, your high beam signal will come on, no biggie, just switch the wires to get it to normal, takes all of 10 seconds, maybe less. Hope this helps, enjoy the brightness
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
