MEVI vs. 2000 Intake ???
Old Mar 16, 2003 | 04:04 PM
makattack's Avatar
The only "major" differences (correct me if I am wrong) between the 4th generation and the 2000 maxima are the exhaust and intake. The difference in horsepower is 37. I just don't see what the difference is between the intake of a 2000 maxima and that of one from the middle east? I am not a mechanic nor would ever claim I could become one but wouldn't it be cheaper to put a 2000 intake on? They use the same block so they can't be entirely different. Just looking for some feedback on the situation.
Old Mar 16, 2003 | 04:14 PM
Anachronism's Avatar
http://forums.maxima.org/showthread....threadid=41105
Old Mar 16, 2003 | 04:49 PM
d_warner's Avatar
Old Timer
Re: MEVI vs. 2000 Intake ???
Send me an email or PM me, and I will tell you all about it. It would probably be better to call me, but I'm not giving that out on the ORG, you'll have to email me.
David
Old Mar 16, 2003 | 05:11 PM
maxspeed96CT's Avatar
The original VQ...
Re: Re: MEVI vs. 2000 Intake ???
David
Y wont you sare with us?? I wanna know too.
Old Mar 16, 2003 | 06:54 PM
hacim105's Avatar
It's because the 2000 intake is a true dual intake where as the MEVI just has a pocket that air is shot into and then continues on where as the 2000 has to air rails one that is shorter and one that is longer. Thus the reason the 2000 gets better HP. Also the reason why it would fit a 4th gen maxima. There is one guy at the moment that is trying to figure and way to do it but no doubt it will cost a lot of money. But who knows? If it works all 4th gen maxima will probably get much much faster with the extra 30hp.
Old Mar 16, 2003 | 07:07 PM
ZuMBLe's Avatar
Aren't there internal engine differences between the VQ30DE and the VQ30DE-K? I thought many of the internals were refined in the K version of the engine. It's not really just the intake and exhaust that is different. I think I read somewhere that 50% of the compenents in the engine were changed in one way or another. The cams are definitely different too. So the variable intake and exhaust don't make up all of the power difference.
Old Mar 16, 2003 | 07:12 PM
d_warner's Avatar
Old Timer
50% of the internals were molybedenum coated. Thats the difference. The 4th gen cams are more radical too. With a 5th gen intake, a 4th gen should be able to produce more than just the extra 32 horses that the 5th gens have. I am a believer that the 5th gen manifold will fit on a 4th gen. I have a 5th gen strut bar on my 4th gen which rubs a little, but it fits. If the strut bar fits, then the manifold should fit as well. The only problem is with the sensor wiring and the complex vacuum hoses on the 5th gen manifold. It will not be an easy swap, but it should be doable.
David
Old Mar 16, 2003 | 07:48 PM
Ramius83
David
Well, you also have to think about something else as well. The actual struts mounts at the top may be in a different location relative to the engine from the 4th Gen to the 5th Gen. So, even though your 5th Gen strut bar fits with little/no issues, if you slap that USIM on, it may still hit the strut bar and/or the hood.....
Old Mar 16, 2003 | 08:05 PM
Nealoc187's Avatar
SLOW
David
Just because the manifold "fits" doesn't mean all the parts that bolt on to it will fit in the same place, which they don't. I'm sure it can be done but it's not as easy as just getting the manifold to "fit" the 4th gen engine.
Old Mar 16, 2003 | 09:27 PM
Dave B's Avatar
Not DAVEB the parts guy
The 4th gen VQ has the same coating. Nissan bragged about this in late 94 when the 4th gen debuted.
Dave
Old Mar 16, 2003 | 09:28 PM
Sprint's Avatar
Dave
hey can you get me the part number on DOT 5 blinker fluid?
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
MichMaxFan
Sep 30, 2015 09:18 AM
