FSTB Installed
Old Mar 21, 2003 | 08:34 AM
bb0ys's Avatar
FSTB Installed
I got a FSTB off of ebay for $32 shipped and I just installed it. I had to adjust the overall length a little and I tried to make each side equally spaced, but the drivers side has a few more cm of threading showing between the bar and the bracket that attaches to the strut tower then the passengers side. This isn't a problem right? Also, should there be any play in the bar at all? I tightened the bolts that go through the very end of the bar and the stut tower brace. I made it tight enough so that the bar couldn't move if you tried to wiggle it around. This won't cause any problems will it?
I know the fstb is rediculously easy, but I just wanted to make sure about stuff.
Old Mar 21, 2003 | 03:21 PM
RapidMax's Avatar
I dont know but I want the answer too since I'm going to be installing one soon so I'm giving this thread a bump
Old Mar 22, 2003 | 02:01 AM
maxspeed96's Avatar
mine is tight and havent had any problems. besides why would u want it loose for? its on your struts to keep them from flexing. so if its loose, youre defeating the whole purpose.
Old Mar 22, 2003 | 03:58 AM
Shoooter_j's Avatar
Tighten it with a torque wrench to about 30 +/- 2 according to www.maximadriver.com (shameless plug for Cheston)
Old Mar 23, 2003 | 12:28 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
i'm pretty sure he's talking about tightening the center bar, not the upper strut mounting nuts.
Old Mar 23, 2003 | 12:47 PM
DTR Maxima's Avatar
i am going to order one from ebay soon as well, how is the fitment issue? is it not even worth it? or do i need to do some hardcore adjusting
Old Mar 23, 2003 | 10:00 PM
(_8*(l)Homer's Avatar
I turned it by hand until it woulnd't go any more. Then turned it with a rag and a good set of pliars about 20 more times. Very tight. Car handles sweet now.
my 2¢
(_8*(l)
Old Mar 24, 2003 | 01:37 AM
Odie96's Avatar
bboys - did you just order some gauges from e-bay too?
Old Mar 24, 2003 | 06:27 AM
bb0ys's Avatar
The car feels much tighter up in the front now. Buying it off of ebay saved me money. The install was obviously easy.
No, I did not buy guages off ebay.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
