HIDs are MESSED up
HIDs are MESSED up
i just received my hanabi 8,000K hids yesterday, installed them, and they worked fine for the whole night. then today, i decided to relocate one of the ballasts after reading some posts on here about ballast locations. I did this before my trip to wal-mart to get some 25 amp fuses for the lights. on the way to wal-mart, i kept the lights off, got the fuses, came out to the parking lot, installed the fuses, popped on the lights, and only one of the lights turned on. then i checked everything over, and nothing changed. drove home, popped the hood again, jiggled all the wires, nothing changed. only thing is that when i jiggled the harness that plugs into the stock harness, i could hear the relay clicking for that same side (the relay that came with the hanabi kit). turned the lights on and off a few more times to see if it would work. then, i went to turn the lights on a 3rd time, and boom, the driver's side light (which was working) turned on, and then went out. now, neither of them turn on. checked all the fuses, relays, connections, etc. no change. i noticed that when i turn on the lights, the dash lights dim slightly as they did when the lights used to work. whats the deal???? i was supposed to leave for a road trip in about an hour and had to cancel the trip!!
Re: HIDs are MESSED up
i changed all of mine and upgraded to higher AMPs.
say 25 to a 35.
make sure everything is plugged in all the way in!
ballast hasnt sank in water or dropped?
any pix of where the ballast are?
dont jiggle the wires... duh
grap each one...should be a blue one a red one and 2 coming from the ballast. make sure everything is plugged all the way in.
and the plug to the stock harness... by the way have u upgraded ur harness?
Really sounds like two bad ballasts you got there. If everything else checks out alright, it's gotta be the ballasts.
And just FYI, it is not necessary to upgrade the fuses, the HID's run on less wattage than stock bulbs do. My 8000k's have worked perfectly for 5 months with stock fuses.
Just some info for thought...
Sorry bout the problems you're having
Hanabi's are Plug and Play...remove stock bulb, insert HID bulb, plug in all harnesses and wires, mount ballast, done.
But if u just bought it you are still under warranty.
ok i just removed the entire kit from the car, and had to mail it back. I'm leaving for school on Friday (will be away from the car for four months!!), so I hope they send them back fast (since i overnighted it). Looks like i'm going to be spending much more money on these things than i thought. both ballasts seemed to have burned out...the bulbs seem to be fine. hopefully i will receive a kit without relays so that i dont have to worry messing with the battery again. why did this have to happen to ME of all people?
i got the kit from Freddie (he's on the org). He sent a new set of ballasts, the ones with the relays. now the lights dont dim, and they seem to work fine. however, i only had a day to test them out, etc...as i am back at school now...wont be with the car agian until late august.
litch
123
01-04-2024 07:01 PM
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
