Engine limping. No CEL and no code.
Old May 9, 2003 | 05:53 AM
Bluebird's Avatar
I am Roid Rage
Last night I replaced the timing ring on my UDP with the new one that RVM sent me. I got the car all put back together and pulled the code for the CEL just to make sure nothing else was coming up. The only code was for the crankshaft position sensor and that was left over from when the old timing ring was on. So I cleared the code and went for a drive. The car started bucking, stuttering, and cutting out in the general area between 1700rpm and 2500rpm and started to do it again around 4000rpm. (I didn’t take it any higher.) It also changes the exhaust / intake note whenever this bucking / stuttering occurs. I thought that maybe I accidentally left the ECU in Diagnose / limp mode but I double-checked it and that doesn’t seem to be the issue. I have no clue what I need to do know. Any ideas?
Old May 9, 2003 | 09:27 AM
BJJ's Avatar
BJJ
Sounds like what just happened to me when my MAF sensor blew, does it idle rough at all?
Old May 9, 2003 | 09:33 AM
Bluebird's Avatar
I am Roid Rage
No, it's idling fine.
Did you get a CEL whn your MAF?
This is driving me nuts.
Old May 9, 2003 | 01:01 PM
FLO_BOY's Avatar
MAFS!!! I had bad MAFS wiring for over a year and RARELY
got a code (even more rare was that the code was for the MAFS).
Did you accidently cut any wires?
Did you accidently pull any wires?
I'd say -- check your MAFS wiring...
Unless you think whatever you changed is making your life hell now?
FLO_BOY
Old May 9, 2003 | 01:15 PM
BJJ's Avatar
BJJ
Yes I did get the code for my MAF, it threw it about 2 minutes after it started acting up.
Old May 9, 2003 | 01:16 PM
BJJ's Avatar
BJJ
Yeah I did get the code for my MAF, the ecu threw the code about two minutes after the car started acting up.
Old May 12, 2003 | 06:04 AM
Bluebird's Avatar
I am Roid Rage
It was the RVM pulley. I took it off and put my stock one back on yesterday so I could take the car in to the dealer today. It ran fine with the stock pulley.
Time to call RVM up and have them tell me that there is no problem with my pulley and refuse to give me my money back.
JoshG
51
Sep 21, 2015 10:41 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 10, 2015 09:35 PM
A32goldylocks
Sep 2, 2015 06:39 AM
