just installed y
just installed y
just had my y throw in. makes my exhaust much louder. only 1 problem. now it rattles like a mother ****er. anything i can do to stop it? it only rattles when i accelerate, usually from close to a dead stop. is this just the normal rattle or is it something else...its ****ing me the **** off, because it soundlike i have this peice of metal banging around somewhere in my exhaust...
will that cause dirt build up in the wrap?
Originally posted by jigsaw
Wrap up your y-pipe with DEI exhaust wrap. Your new y-pipe will be easier to remove than the original. Just take the pipe off, wrap, and hose clamp. It should be much quieter...
i just went back to budget and they welded something down there so that the rattling would stop. i suspect that if you took it to a local muffler place they would just do it for free (take it when they're not busy) it only took like 2 mins.
I had a rattle right after my y install. It was mainly when letting off the gas at high RPMs. It sounded as if it was coming from the rear of the car, though. Even though I only changed out the y, with the cat and b-pipe hanging by themselves for a few minutes, it caused a shift in the b-pipe. I found the b rubbing two different places against the heatshields. Something you might not think about that you should check.
Originally posted by Torgus
i will not live with the rattle. you MUST take off the y. it is easier to be taken off when its not the stock one..much easier to get too..you don't even need a lift.
seeing as how it looks like it might cost 10 bucks to fix, being exhaust wrap, and having a few things welded on to stablize my exhaust for free...still less expensive. though we'll see how much it costs to get rid of it...it will not rattle when im done with it i swear!
I don't know, maybe it's just me. My friend rode with me and he said it sounded hot, and he stood outside the car and he said it sounded nice. Maybe I'm just a picky guy. I told him it kinda sounded like a lawnmower, but he said not really, just nice growl too it. Maybe if I find a tape recorder i'll post the sound and see what you guys think
where do u go to get exhaust piping wrap..how much does it cost..anyone have a pic of thier y with exhaust wrap? when i get a y i will do this forsure.. dont want any rattling noise..
you buy it here: http://www.designengineering.com/exhaust_wrap.html
you learn how to put it on here: http://www.motorvate.ca/mvp.php/520
Originally posted by markargente
Where can you get the DEI exhaust wrap and is there a way to not take off the pipe and install the wrap. I went through a lot of trouble installing it, and I don't want to go through it again.
My y-pipe used to make a rattling sound but I found what the problem was. My rear 02 sensor was not screwed all the way down so it caused it to hit the heat shield above it. After I screwed the sensor back in, the noise was gone. By the way, exhaust wrap does wonders for aftermarket y-pipes.
MaxLife17
06-27-2019 01:37 PM
