Starter Replacement
Old Aug 1, 2003 | 01:02 PM
Eddi79's Avatar
Starter Replacement
Hi,
yesterday the starter of my Maxima QX 3.0, 96 automatic refused to work - I could only start the engine when I hit with a hammer or something similar on the starter. So I decided to replace it next week. But how ??? Has anyone of you an idea ? Or a link with instructions ? Do I need special equipment ?
I am from Germany (sorry for my bad English)- and here this car is very rare. So no one could help me.
Thank you very much
Markus
Please mail to: ich@ederermarkus.de
Old Aug 1, 2003 | 01:11 PM
PoePoe2797's Avatar
Your english is pretty good actually, better than some people here in America. Heres the directions for removal and installation:
1) disconnect (-) battery terminal
2) remove the air duct
3) disconnect the starter wiring, noting original positions.
4) remove connector brackets.
5) remove the starter-to-engine bolts, and remove the starter from vehicle
INSTALLATION
6) hold starter in position, insert & tighten the attaching bolts. be careful not to overtorque the mounting bolts because it might crack the nose of the starter case
7) install the starter wiring in original positions
8) install the air ducts and connector brackets
9) connect (-) battery terminal
10) start the engine a few times to make sure of proper operations
Hope this helps as you can see, I was trying to type this quick
Old Aug 1, 2003 | 02:17 PM
sharkyjay's Avatar
Hope this link helps:
http://www.cybrrpartspro.com/Chilton...61CH02_22.html
Old Aug 1, 2003 | 03:00 PM
PoePoe2797's Avatar
HEH, thats pretty funny because thats the same exact thing I said except that has 2 pictures
Old Aug 2, 2003 | 01:01 AM
Eddi79's Avatar
Thanx
Thanx a lot, I will try it this week.
Markus
INSTALLATION
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
