another low-end power thread
Old Sep 15, 2003 | 03:14 PM
dantheman598's Avatar
ok ive searched and read posts and posts and stuff, and i keep getting contradicting views. ive got a 96 maxima with 163000 miles, getting up there, and im going to flush everything and change the belts with its oil change at 163000 miles to try and get some of its old kick back. but i need more low end torque. the '03 max (yes, with the different VQ engine i know) is so much punchier in the low end than mine, but the feel behind the wheel is so different my numbers have to be lagging more in the old car than what im reading on paper. basically, what im getting at is that i want more low end torque (1500-3000 range) like everyone else and their dead cat does. ive read from you posters than HAI's will increase it, CAI's will increase, HAI's and CAI's will decrease it, stuff like that, and i dont know what to believe. how about a Y-pipe? turbocharger? supercharger? i know im not going to get punch like the '03 max but i know this 96 beast can do more than it's doing.
Old Sep 15, 2003 | 03:20 PM
bobjohnson's Avatar
Blazin......
start cleanin every little Part, IVAC, TB, Intake maniflod, Replace vacume hoses and Get a haynes.
Then u got tourqe, also invest in O2 sensors or Knock sensor. ur welcome.
btw all those other parts that cost $. read all the forums like 10 pages back,thatll answer all ur questions.
Old Sep 15, 2003 | 03:25 PM
wow you lost me on all of that...
Old Sep 15, 2003 | 03:26 PM
venompwr2's Avatar
I'll be honset with you...I had just a pop charger, I was happy with it- first mod, sounded good and some better throttle response, but did lose some low end. During the summer of 2k2, the big thing was starting to be these hybrid/frankencar intakes. So I put on a mid pipe, souneded much louder- supposedly it was to "give you back the lowend lost from the pop charger" thats a false claim- it doesnt.
Mine is auto, so that might make things a bit worse too. Then I got all the exhaust mods (Y pipe, b pipe and muffler) and still felt like I was lacking in lowend, but actually take off much better than other 5spd maximas did.
Turbos, you're not going to have that lowend either because the turbo needs to spool up, but ultimatly can make more power. The supercharger is going to give you steady power across the band, and isnt bad. I went the nitrous route, and suddenly low end didnt matter anymore because at 3k, it pulls HARD to redline.
I guess if you want this low end either get a CAI or hack the airbox- but get a Y pipe anyways, they are a good mod.
Good luck
Justin
Old Sep 15, 2003 | 05:37 PM
njmaxseltd's Avatar
Keep your intake stock for the most low end torque. Disassemble your intake and clean everything out and you'll be suprised at how much more low end you'll get back in your engine.
Old Sep 15, 2003 | 06:39 PM
Nismo87SE's Avatar
One thing you can do it improve off the line performance is goto lighter/smaller tires. For example buy some lightweight 15in wheels and put some 205/50-15 tires on them. This will give you more torque multiplication since its like increase the final drive ratio. The only other way to get more torque multiplication would be to swap out the differential gear from the stock 3.62 to say 4.18 from sentra/200sx se-r. My vote goes for the wheels/tires instead.
Old Sep 15, 2003 | 07:30 PM
lilgrebbie's Avatar
163000mi and your just starting to mod it out? Bolts ons are ok but I definately wouldn't recomend a turbo/ supercharger.
Just my 2 cents
Old Sep 15, 2003 | 07:32 PM
i just got the car at 160k, that's why
plus, people say these cars run to 250k +, and i really doubt ill drive it 100,000 miles in the next year before i go to college, i just want a couple ideas so itll gidup and go a little quicker thats all
Old Sep 15, 2003 | 09:10 PM
BEJAY1's Avatar
Conecarver
Of course make sure everything is maintained and clean first. Then I agree with Nismo87SE about reducing the rolling weight. That and the CAI and UDP seemed to help my low end torque. I've seen as high as 197tq to the wheels at 3500rpm. Factoring for lighter wheels/tires I've got a weight/tq ratio of 11.9 at that rpm. I bet on a good day I can break under a 6sec 0-60mph. That's enough punch for me.
Old Sep 15, 2003 | 09:57 PM
nismos14's Avatar
§è~® f®ÈÄk
The only other way to get more torque multiplication would be to swap out the differential gear from the stock 3.62 to say 4.18 from sentra/200sx se-r. .
anyone have any more details about this?
Old Sep 16, 2003 | 07:11 AM
UncleMax98's Avatar
Check the knock sensor. If it is bad, the engine loses a lot of power. Do a search. There were a lot of info about knock sensor a few weeks ago.
TallTom
57
Oct 14, 2025 05:16 PM
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
sliptap
Sep 30, 2015 05:57 AM
zmcneely13
Sep 26, 2015 02:26 PM
