need help, belts install
Old Oct 4, 2003 | 05:26 PM
SuperFishstick's Avatar
So im putting on my UDP, and i can't put the belts on. The power steering bellt. How do i loosen the pulley so i can put the belt on. Urgent, car is up in the air, and can't seem to put the belt on!
Please HELP
Old Oct 4, 2003 | 06:16 PM
Please HELP
come on.. please. I have loosend all of the bolts that i think i need. One behind the PS, and on the front. What else?
Old Oct 4, 2003 | 06:38 PM
nismomaxima97's Avatar
Well, I'm not sure if you did this but untighten the belt tension screw. This screw is located between the Crankshaft pulley and the Alternator. This tension screw pushes down on the idler pulley so maybe this is your problem. Oh and I think you already saud you did this but make sure you untighten the other tension screw behind the Power steering for the small belt. Hope that helped if not post again.
Ciao
Old Oct 4, 2003 | 07:08 PM
Ciao
yeah, i got that one off. I got them both off. Now the new ps belt wont fit. I got the screw behind the ps ( 14mm) and the two tension screws on the ps. The other long belt is no prob. HELP
Old Oct 4, 2003 | 07:09 PM
BluFlame's Avatar
You have to loosen the pump I think there is 1 screw that holds it, look around the pump it should be there. Idler pulley is for the alternator.
Old Oct 4, 2003 | 07:10 PM
i got that screw behind the pump loose. its a long one, 14mm. Tough to get at, but i got it. It still won't barge
BluFlame's Avatar
PS pump can be stuck in place, try force. or a metal bar.
Old Oct 4, 2003 | 07:14 PM
thanks, i'll give it a try. Also, i think i got all the bolts right?
Old Oct 4, 2003 | 07:26 PM
nothing still one barge!
Old Oct 4, 2003 | 07:30 PM
BluFlame's Avatar
I never really done it but i worked around PS pump and I took a good look at it. It is a bolt that's at a 90 degree angle, not clearly visible from front. You need to go under and behind, i think. If still in doubt loosen everything around it, except hoses & pressure lines.
Old Oct 4, 2003 | 07:32 PM
ill keep trying
Old Oct 6, 2003 | 12:09 PM
well i got my pulley installed and all the belts as well. Gains are moderate, kind of what i expected. The car revs more freely and with the A/C it has more kick than before. Over all i'm satisfied. I'd like to thank BluFlame and nismomaxima97 for the advice, which came in handy. Thanks guys!
Old Oct 6, 2003 | 12:16 PM
No problem Bro....Anytime
What was the problem in the end, how did u end up getting the ps belt off?
Ciao
MaxLife17
Jun 27, 2019 01:37 PM
markevans999
Oct 25, 2015 08:27 AM
RWCreative
Sep 21, 2015 11:01 AM
2kmaximel
Sep 16, 2015 03:19 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
