I use my cig lighter for tons of things. I need to bring in a new power source? How?
Old Dec 22, 2003 | 09:11 PM
ManualMaxima's Avatar
5th Gen till she dies!
Righ tnow i have alittle to many thigns hooked up to my cig lighter. i want a new power sorce that i can tap into either fomr the engine bay( go into car by firewall), or from the interior. i want it to to on supply power when ever the car is on. i htought abot doing teh radio antenna but i want to be able to turn it on when ever the car is on and not the radio. any suggestions?
Old Dec 22, 2003 | 09:16 PM
Pats5spdi30T's Avatar
Map Lights? I have my Radar Detector there.
Sunroof switch?
Old Dec 22, 2003 | 09:18 PM
SXN's Avatar
SXN
What stuff do you have running off of the cig lighter? I suggest hard wiring some of that stuff, instead of just plugging more and more in. Neons should be hardwired, 100%. Radar detectors are a lot nicer hardwired, and there are instructions for it in the how to thread. I need more detail about what you are running
Old Dec 23, 2003 | 08:18 AM
i taped the wire to the cig lighter for power....so my plug has nothign in it. I have 4 underseat neons, a radar detector, 2 strobes, i use my phone carger often. i just kind thought that was alittle to much. I just need soemthign eles.
hey snx did you clear your own tails out?
Old Dec 23, 2003 | 08:19 AM
Pats5spdi30T map lights??? wouldn't they ahve to be on for the power to work?
Old Dec 23, 2003 | 11:55 AM
1MAX2NV's Avatar
Get the power directly from the battery. Use a relay and use the cig. lighter as a signal source or anything that's switched at a signal source.
Old Dec 23, 2003 | 12:01 PM
Ludacris's Avatar
Has anyone used those splitters for the outlet? You plug it into the one outlet and have two outlets...are they worth it? I need to have one for my phone charger and iPod..
Old Dec 23, 2003 | 12:23 PM
jamier2's Avatar
I had one of those in another vehicle once. It worked fine, but isn't pretty.
I'd rather install a power outlet or two somewhere on/in the console so it would look nice, and be more permanent.
Old Dec 23, 2003 | 12:38 PM
ZuMBLe's Avatar
Heated seat switch. =)
Old Dec 23, 2003 | 03:49 PM
R5a7B's Avatar
i have the same problem. I bought a StreetGlow OPTX 4 Outlet thing I'm using now until I hardwire everything. Not bad for $10. For now, I only have radar and Sharper Image Air thing plugged in.
Old Dec 23, 2003 | 04:37 PM
PearlWhtMaX2000's Avatar
what i did was run a switch from one of the fuses, and hard wire everything to that. its great, and i got a button to press eveytime i wanna turn things on. ex: neons.
Old Dec 23, 2003 | 07:40 PM
I ground it in the frame near the map lights and I tapped off one of the wires near the map lights. It is always on and it does not affect map lights, I really wanted to tap into the sunroof switch but I could not find a place. the wire I did choose does "self check" when I start the car. What I mean it goes through all the lights and beeps. I will check tomorrow to see where I tapped. The only wires are visible from the map lights area and straight under the sun visor and to the radar detector.
Pat
BTW I moved from Lawrenceville GA earlier this year, I lived off Bramblet Shoals, close to Grayson.
Old Dec 23, 2003 | 09:06 PM
R5a7B's Avatar
Do you have a writeup of how to do that?
Old Dec 23, 2003 | 09:29 PM
I have one of those sharper image air tings as well, and indiglo petals. i got splittle taht splits it into 4 but it is filled...to many things.
Old Dec 23, 2003 | 09:31 PM
R5a7B's Avatar
those air things are great.
only downside to the 4 plug outlet is the tape they give you with it is horrible and keeps falling off on me.
Old Dec 23, 2003 | 09:47 PM
they are tight, i have a habit of puttin my hand over the air outlet hole, and the smelling my hand afterward cause it smells like the clean air. hahahahahahaha
Old Dec 24, 2003 | 06:09 PM
R5a7B's Avatar
Haha, I'll have to try it now. They really are worth the money tho for those of you who were thinking of getting one.
Old Dec 24, 2003 | 06:21 PM
sharkulator's Avatar
How much are those things and where do you get them at? My max has a kinda funk in there that I cant get out with anything. I have tried coffee grounds, febreeze, and all carpet cleaners and there is still that o' de funk. I think it is because the guy who owned my baby before I did smoked cigars in there.
Old Dec 24, 2003 | 07:42 PM
R5a7B's Avatar
http://www.sharperimage.com/us/en/ca...id=1&catid=103
$50 with shipping, I think it worked very well in my car. And everyone thinks its awesome. Also, it has a blue LED which is nice looking.
Old Dec 24, 2003 | 08:31 PM
happyricefob's Avatar
V^___^V
except mine splits into 4 outlets.
1st outlet = Cobra ESD9115 Radar Detector
2nd outlet = LightGlow Blue Neon Rods 15" driver's side
3rd outlet = LightGlow Blue Neon Rods 15" passendger's side
4th outlet = Razo ZAX Blue Console Spot Light
running 48Vs total. all wires are under the carpet. nice and clean. very convinient rice setup
Old Dec 24, 2003 | 09:12 PM
honestky i do not think it is worth the money you pay for it.i would not ever buy one...i found it ina parking lot! i do not even use mine.
hey happyricefob is that radar detector really acually functional there? I am just asking cause if it is, i might have a new place to put mine!
Old Dec 24, 2003 | 09:24 PM
V^___^V
anywhere on the windsheild works A+++++
TallTom
57
Oct 14, 2025 05:16 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
