Passenger Power Window off Track
My passenger power window is off the track. I can roll the window down but it won't roll back up. The motor in the door is working but I have to pull the window up by hand. Is it hard to put the glass back on track? If not, what are the steps to doing it myself. There isn't any info on putting the window back on track in the Haynes Repair Manual. Thanks
Taking the window out of the door is fairly easy. This happened to me before when my window was off track. Have the window rolled all the way down, take the door panel off, and notice the bottom of the glass held onto a bracket thru the openings of the door. Get the window to the point where you can see the bracket holding the glass by two bolts thru the openings. Remove these bolts while holding onto the glass. Remove glass upwards being very careful not to drop it. Slightly remove the rubber tracking around the trim of the door that the glass rides on. Push it back on track and apply some silicone spray between the tracks. Re-install glass back and see if the glass moves up and down freely. I'm believing it should because it worked for me. I hope this helps you out any.
Maxima30
09-07-2015 06:13 PM
ef9
09-05-2015 11:18 PM
