power steering pump really whiney.
Old Jan 9, 2004 | 09:57 AM
Max240's Avatar
just since it got cold, whenever i start the car up, the power steering pump is really pretty loud. when you try to turn the wheel, it is sometimes very hard and a little shaky. you can also here the belts squeeling a little. once it warms up, it seems to be ok. is this just because the fluid needs to warm up or could it be a bad pump? it does not do the same thing in my 3rd gen. anyone else having similar issue?
Old Jan 9, 2004 | 10:28 AM
Midknight MAXX's Avatar
The belt is either worn or the tension needs tightened.
Old Jan 9, 2004 | 12:48 PM
Phatmax98's Avatar
Is your fluid full? You said squeaky belt too..maybe it is loose..or you could just need a new one.
Old Jan 9, 2004 | 02:33 PM
Kevlo911's Avatar
Kevlo for President
Tighten hte hose clamps to the power steering container and if low, fill up with ATF
yes, that is correct, ATF
lowpost99
Oct 26, 2025 06:53 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
rnb754
Sep 14, 2015 11:39 PM
SusieQQ
Sep 9, 2015 12:14 PM
