Window fell down today, fixed it for free. :)
Old Jan 14, 2004 | 10:14 PM
izzydig's Avatar
Well today, I went and stopped my car, went inside for a few hours, and came back out...and found my rear passenger window completely rolled down (it was up before). Of all days, it happened when it was sprinkling rain in the middle of the desert.
I try and roll it up, and no go. So I take apart the door, take off the window guide, window motor and cables and find that the little plastic pieces that are attached to some metal stubs that hold the piece of metal crimped to the window cables, had broken off. It's quite hard to explain, but i got my window working again without spending a dime (all in a light rain mind you).
Anyone ever see that before (window just goes poof and falls down)? It took some mechanical wizardry to reassemble that bad boy (window system), but it went smoothly considering I had no manual or writeups on it in front of me. I had to realign the cables on the the window motor pulley as they had gotten off-track when I attempted to close the window. I also lithium greased everything I could since I was in there already.
Well to all you folks who ever have a problem like that, keep in mind it's fixable. I guess I coulda bought a new window support, but...nah.
-'95 max with 232K miles.
Old Jan 14, 2004 | 10:36 PM
Bmr4life's Avatar
happened to my roommates 93 accord before. cept it was his drivers door window and it was a biotch to get back to working right. Also, his didn't just fall, he had rolled it down and it just wouldn't come back up.
Old Jan 14, 2004 | 10:43 PM
happyricefob's Avatar
V^___^V
it just happened to me 2 weeks ago... dont' know how to fix it and where to fix it.
so...i taped it yea i know it's ghetto but it works for now. they plus they can't really see through it unless they stand really close to my rear window. yaYy for 35% tint.
Old Jan 19, 2004 | 07:17 PM
DjcmSS's Avatar
Same thing goin on with my car, was driving an noticed after every bump the window went further down, if i put it up it falls right down again. Now i have it jammed up there until i can get it apart to see if i can fix it myself w/o having to spend any $$$.
Old Jan 19, 2004 | 08:13 PM
Vortex SE's Avatar
I just had the same thing happen. Izzydig, how did you fix the problem? The plastic piece is broken and I believe that only the motor assembly is sold not just the individual parts.
Vortex SE
Old Jan 19, 2004 | 08:40 PM
helaesus2's Avatar
I fixed mine when it happened. There is a little metal thing on the cable the brings the window up and down. I used the uber-glue I've got to glue it to the plastic hodler thing. Not had a problem since. Been about a month and I use it almost every day.
Old Jan 22, 2004 | 03:40 PM
lawrences1_087's Avatar
Try calling your nissan parts dealer, you can buy the window regulator w/o having to buy the whole motor $80 in HI and 115 to have it installed by mechanic so appx. $195-maybe less in the states.
Old Jan 23, 2004 | 07:51 PM
izzydig's Avatar
Doh! Shoulda used Uber Glue(super glue? lol..don't know what that means).
But yeah, basically the plastic tabs that are on the metal thing pull the window up and down. Those Broke.
Gonna open the door up again this weekend and use some epoxy to keep it from slipping out again. The epoxy should make a bridge between the two metal/plastic tabs that hold the pulley wire in place. I hope I find my digital camera to let you all see what goes on....back to drinking more beer.
Old Jan 23, 2004 | 08:06 PM
helaesus2's Avatar
Naaa, it's this stuff 3M makes. It hardens into the plasticky **** that can pick up a bus.
Old Jan 24, 2004 | 05:31 AM
007max's Avatar
those damn plastic pieces definitely were not designed to be exposed to heat. back when the max was my dad's car every single window did that at some point, only he had it fixed at the dealership for like $350 each time... of course he also had them replace burned out bulbs for like $35 in labor for each one
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
