Fog Lights are out, need help..
Old Mar 19, 2004 | 09:01 AM
Grimey's Avatar
Recently I bought some aftermarket bulbs for my stock fog lamps. I replaced the stock bulbs with some 65/55w "superwhite" bulbs. After I put the bulbs in, the lights didn't turn on at all. I figured that I had some crappy bulbs, so I then put the stock bulbs back in. Again, no light. I then checked my fuse for the fog lamps (if you are facing the engine, I replaced the fuse that's in the fuse box on the right). Sure enough the fuse was open. I replaced the open fuse with a new one, and still no light.
Any help would be appreciated. If you need me to further explain, go ahead and ask..
Old Mar 19, 2004 | 09:04 AM
Kevlo911's Avatar
Kevlo for President
Did you hook up the wires correctly? H3 is a single filament bulb. It should only be 55w or 85w(high).
Replace the relay if needed.
Old Mar 19, 2004 | 09:08 AM
MaxedOutOfCash's Avatar
Pizda Boy
check the fuse again...you probably blew it out again...
Sam
Old Mar 19, 2004 | 09:56 AM
Grimey's Avatar
Well I went back to the fuse box, and Sam you were right. The fuse is out again. I tried one more fuse, and again it went out. Any suggestions?
Oh, Kevlo... what relay are you speaking of?..
Old Mar 19, 2004 | 10:57 AM
Kevlo911's Avatar
Kevlo for President
There is a short somewhere if the fusr keeps blowing.
Old Mar 19, 2004 | 11:56 AM
Pizda Boy
i had the same problem and went through about 6 fuses....
i took the fogs off, took out the bulbs, put them back in, put a bigger fuse in & it never happened again....
put a bigger fuse first...if it burns, check your connections...wire might be touching something else and it's blowing the fuses...
Sam
Old Mar 19, 2004 | 05:52 PM
MIXXMAX's Avatar
A multi-meter also helps. It's a great tool for checking correct voltage and any short circuits you may have.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
