View Poll Results: Needed a ignition coil change?
Yes
103
54.50%
No
86
45.50%
Voters: 189. You may not vote on this poll
How many of you max owners have to replace the ignition coils?
Old Sep 7, 2005 | 07:04 PM
  #41
2 Da Max's Avatar
knock on wood never have to change it, if i have to change anything else on this car or dump any more money into it im burning it
Old Oct 10, 2005 | 09:56 AM
  #42
GodFather's Avatar
Made in Taiwan
i got splitfire ignition coils. i think they kick azz here-->no low-mid range loss + strong after 5000 rpms...
Old Oct 10, 2005 | 12:40 PM
  #43
nfafan's Avatar
Even though I have a 99, I still signed this petition for whatever worth that will be in the long run for Nissan Max owners...
http://www.petitiononline.com/NIS_IG...ion-sign.html?
I only had to change the #2 coil, at just over 50K 3 months ago. Not enough dinero to change all 6 at the same time.
I know they won't last forever, but they oughta last at least more than 50K.
Old Oct 10, 2005 | 12:49 PM
  #44
maxspeed96's Avatar
I have 182K on my 96 and theyre still good (knock on wood)
Old Oct 10, 2005 | 01:16 PM
  #45
95MaxRB26-DETT's Avatar
367K, never replaced. I must be lucky ?
Old Oct 10, 2005 | 01:24 PM
  #46
brad kay
Originally Posted by jgrafe
I had hesitation and misfire symptoms. The code indicated a cylinder #1 misfire. I replaced the spark plugs with the NGK platinum plugs ($10 each) that are recommended for this car. I also ran some injector cleaner. I replaced the air filter. Had replaced the fuel filter last year. Car runs much better. The car has more horse power. However, I still notice a slight hesitation or misfire, but no codes. What do I check?
i was throwing a cylinder #3 misfire about a year ago, but i was running nitrous and had not stepped down to colder plugs yet. so i replaced the spark plugs with a step colder and have not thrown any misfire codes since then. so i've been assuming that my misfire problem had to do with the plugs, but i suppose i should check my coils as well just to be sure.
Old Oct 10, 2005 | 01:48 PM
  #47
maxspeed96's Avatar
your car = energizer bunny
Old Oct 10, 2005 | 02:33 PM
  #48
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
not yet, but I know the coils will go adios at my next tuneup
Old Oct 10, 2005 | 09:31 PM
  #49
Chapman99SE's Avatar
HAHA funny timing for me to see this post because i just replaced my #2 coil this morning on my 75k '99, it started misfiring on the #2 cylinder and threw a cel along with a very rough unbalanced feeling, sure nuff no spark was being delivered and the coil was the culprit, $60-70 at auto parts stores but nobody had one in stock and i had to get to class on time so $108 at Baron Nissan
Old Oct 10, 2005 | 09:34 PM
  #50
Thanks, but it makes me nervous though! Cars that go forever w/o problems are the ones that die altogether, all at once!
Old Nov 2, 2006 | 10:51 AM
  #51
lunaillij's Avatar
I had the same problem as "jgrafe." I replaced three coils and installed NGK sparks and replaced the knock sensor. My max ran good for a few months, but then my max started to have hesitations/misfires again. I changed the plugs, again, but with Bosch, it made it worse. So I went back to the NGKs, and the hesitation is gone. but when I'm stopped at a light, the engine sometimes misfires. any ideas why?
Old Nov 3, 2006 | 02:15 PM
  #52
EnervinE's Avatar
i has college
Way to go, you just successfully bumped a year old thread within your first 5 posts. Learn how to use a forum board before you **** some members off...
Old Nov 3, 2006 | 11:43 PM
  #53
lunaillij's Avatar
no reason to be a ****
Old Jun 28, 2007 | 07:04 PM
  #54
WielkiWaac's Avatar
MaximaDriver
i changed all 3 from rear bank, only one was bad
Old Jun 30, 2007 | 02:52 AM
  #55
hobokenkid's Avatar
replaced all 6 at 29,500 miles yes 29k not 129k seems to happen to the 1999 models more frequent
Old Jul 21, 2007 | 02:15 PM
  #56
ThurzNite's Avatar
Oops, I shoulda read this thread before starting a new one
http://forums.maxima.org/showthread.php?t=530042
202k miles, just got a new one. I'll replace them as they die out.
Interesting to note that the local dealership keeps these in stock... sounds like a pretty common thing.
Jae
Old Jul 27, 2007 | 11:00 PM
  #57
hybridc24k's Avatar
Mine have been replaced.
www.sparkplugs.com has the denso ones.
Denso COP Boots-6 671-6251 671-6251 Coil on Plug Boots, Hanshin Coil $56.65
Denso COP Boots-6 671-6252 671-6252 Coil on Plug Boots, Mitsubishi Coil $61.60
Old Jul 30, 2007 | 03:35 PM
  #58
Liso's Avatar
I replaced all 6 at 99k, as two were bad and I figured it was only a matter of time before the remaining 4 went south. That bill was not fun...
Old Jul 30, 2007 | 05:09 PM
  #59
Maxtank's Avatar
160K on my SE-L...they are still going strong!
Old Aug 2, 2007 | 07:45 AM
  #60
skuccio's max's Avatar
Beast Mode!!!
Bought my '99 at 120K miles with a couple of P1320 SESs... dealer fixed them under warranty, car runs like a top
Old Oct 3, 2009 | 06:04 PM
  #61
gpresar's Avatar
I replaced all six @ 120K miles in my 00 GLE. The symptoms included lots of pinging and intermittent roughness. Been working great since the replacement.
Old Oct 3, 2009 | 08:20 PM
  #62
Blackwind's Avatar
jesus dude!! 2 year old thread?!! did you need to report your findings for government research?
Old Oct 3, 2009 | 11:38 PM
  #63
OnlyMe's Avatar
My 95 Maxima has 171,000 miles, and the coils, HANSHIN, are still good.
BTW, when it is time to replace the coil, which brand should I buy, HANSHIN or MITSUBISHI? Can you also explain why you recommend that brand and not the other. Thanks.
Old Oct 5, 2009 | 12:40 PM
  #64
ThurzNite's Avatar
Get any you can find with lifetime warranty. Kragen sells them.
Old Oct 7, 2009 | 08:07 AM
  #65
Juscruzn's Avatar
All 6 at 150k. Ebay coils, so far so good!!!
Old Oct 11, 2009 | 10:26 PM
  #66
scottbrew's Avatar
i did but only after i had to replace the ecm
Old Oct 12, 2009 | 03:41 AM
  #67
Maxima9499's Avatar
I replaced one of my coils in the 1 year that I had my 99', turned out to be bad wiring was the issue. Ended up hitting up junkyard and cutting out female injector plug and pigtail and wiring it into my existing harness.
Old Oct 13, 2009 | 08:10 PM
  #68
komik's Avatar
I bought my Max with the CEL on for a Cyl 2 misfire. I replaced the coil with one I bought from fanaticrockford on this board. 20,000 miles later all is still well. (Now at 252K)
Old Oct 14, 2009 | 05:01 PM
  #69
BIG D MAXX's Avatar
i have over 163K and still havent had to change them its a 99, Knockin on wood now.
CRizz
41
Jun 7, 2021 05:42 AM
maxinout93
Aug 20, 2015 02:17 AM
Balkins
Aug 12, 2015 06:39 AM
Mcnabb34
Aug 11, 2015 08:45 PM
maxima297
Aug 3, 2015 12:50 PM
